Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - worth beefing up stock s10 rear?
Old 02-18-2011, 07:40 PM
red65novawagon red65novawagon is offline
If set up properly these rear end will handle quite a bit of abuse. First find a c-clip elminaters kit with aftermarket axles, use a solid pinion spacer, (the stock crush sleeve will collapse) and girdle cover. I have a friend that pulls the front wheels 2 feet in the air for 100' at the strip with a 355 on nitrous in a 86 I-ROC and runs low 11s.
