worth beefing up stock s10 rear? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-22-2011, 09:27 PM
runn141's Avatar
SB S10
lowest factory ratio ive seen is 3.73.
  #17 (permalink)
Old 02-25-2011, 06:15 PM
Wiki Edits: 31
4.10's were fairly common with 2.2L trucks
If you do not want to register, fill this field only and the name will be used as user name for your post.
Is aTH200R4 transmission worth beefing up for street use? jody chevelle Transmission - Rearend 6 03-04-2007 11:09 PM
bigger than stock lifters, is it worth it? 406 ss monte Engine 2 03-29-2006 02:39 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 12:19 AM
corvette c3 beefing up the rear end. genochevy1 Transmission - Rearend 6 02-20-2005 01:07 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
