Worth the change? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2005, 07:33 PM
old69's Avatar
New Member
Worth the change?
I was just looking for some advice, I have an 8.2 10bolt with 3.08 gears, and was wondering is it worth it to put 3.73's in it or wait untill spring carlise and look for a 12 bolt w/ maybe 3.55 or 3.73's? also would the change to 3.73 be a big noticeable difference? The car has a sbc 350 nothing wild, 650 edelbrock carb,an older streetmaster intake, double hump heads, headers. And a m-20 transmission. I'm also running 15" tires. I'm looking for a little more torque. I dont race,so thats not an issue. By the way its a 69 Camaro,plain jane. Thanks .
Old 03-21-2005, 08:52 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
You will defiantly "feel" the difference with 3.55 or 3.73 gear. If it were me with your mild set up I would use a 3.55 gear and just use your 8.2. Esp if you consider how high fuel is getting! just my .02
Old 03-22-2005, 06:36 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
3.55's will give the best results of both mileage AND acceleration from a stop.
cam change projectRam Engine 1 06-03-2004 12:54 PM
to change intakes or not chevellenut Engine 6 12-07-2003 07:23 AM
shifter change KNIGHT07731 Transmission - Rearend 0 06-23-2003 08:03 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
change heads corenele Engine 3 08-26-2002 01:19 PM
