Is it worth Dyno tuning?
I have been driving my new built 402 sbc for about 3 months now and I really want to get the most out of it. The local dyno -tune shop wants 425.00 for a full tune. It seems to me I can get most of whats left in her myself with a little time and short money. I have never done anything to a carb other than rebuild it with stock parts. I have a .020 over 400ci with a CC 270HR , RHS (220) heads, 9.7 -9.9 CR. ,Weiand stealth manifold and one of those Summit 750 carbs on it. I know there is more power in there, I just need to extract it. It does hesitate when I stomp it, but if I roll into it , it really pulls hard. I have been told to get the vac pressure and change the cam or pump shooter . It looks like the summit carb uses holley parts .The kits I found @ summit are http://www.summitracing.com/parts/SUM-M08040/
and http://www.summitracing.com/parts/HLY-20-12/ So, I'm into this for about 80 bucks. I feel comfortable in doing the work but how will I know if I am leaving anything (HP) in there? Do these Dyno shops really give you 425 .00 worth ? I have never had a Dyno and work hard for my money. Help Me Hot rod Nation!! what would you do ?
You can get most of what it has yourself but typically the term "a little time" doesn't apply as you have to use the old fashion cut and try methods which tend to eat up a lot of time as you try various combinations; test them for their results and re-modify and adjust then test again. Bogie |
Almost impossible to solve most drivability issues on the typical chassis dynos most shops have.
You need a dyno that can load down the motor at various loads and speeds. Eddy current type. Most of the chassis dyno shops have a inertial type, (dynojet) You are tuning a big drum of a known mass. Good for acceleration testing but thats about it. The cam in your 400 with huge 220cc port heads is really small. You could spend 425 and get 30hp or spend $300 on a real cam and pick up 100 hp. Is there some reason you went with such a small cam in this motor? Most of the drivability problems you can solve yourself with a vacuum gauge, a simple narrow band afr meter/ 02sensor and drive test tuning. It takes time to do this. The chassis dyno shop will also charge you for any and all tuning parts used to tune your car unless you bring them. |
Yeah, I know it is small, I wanted to go bigger and was talked down by my engine expert because It is my daily driver and rarely turns over 6000. It sounds and drives great but I wanted a little more chop. Maybe I will consider upping the cam at a later date,but for now, I have to run this one and just want the most out of it. As far as the heads go, I figured I will probably have them for the rest of my life (if they last that long) and RHS said they would be pretty good w/ the 270 ( and they are ) and there is plenty of room for more cam in the future. Getting back to the Dyno, sounds like a bunch of smoke and mirrors to me I think I will pick up a vac gauge and start from there. I won't learn anything if I don't do it myself. Also, Do you think it would be worth it to pick up the summit tuning dvd for their carb ? Or is it going to be the same old trial and error ? Right after I bought the 750, ( like a week later) they came down on price and threw in the dvd, now, to get it separate they want 25.00 for it. I forgot to mention its a two bolt BTW - What would you consider for a cam given the application? Thanks, Matt Last edited by Fast 4 Door; 07-23-2010 at 09:31 PM. |
Bogie, The Dyno shop Will give me 4 pulls for 75.00 .( of course they won't let me work on it between pulls ) That being said, The only real "test" is at the track, something we don' t have nearby. The other "test" site is a stopwatch and a couple of landmarks on a nice flat straight road,that we have I don't know, could be wasting my time ( and yours) It just feels like it wants to go more but something in that big old 4-door is holding it back. I think I am going to get a quick 4-pulls and some results. Does anyone know what kind of power this thing should be making ? Thanks for all the help, I appreciate it.
four door:
I have to charge a bit extra to put on my "Amazing Carrnac" hat and guess at your specific car/engine combo details. " Remote viewing" makes my head hurt. If you let me in on this I will recommend a good cam for free. |
Daily street driver 1965 Belair 4-door. . its heavy ( Weight unknown ) stock rear end ? 405 ci. 2-bolt flat top hyper speed pro pistons stock rods - 5.56 9.95 - 1 CR deck .025 RHS 12305-02 72cc 220 runner 2.02 -1.6 (.600max lift) TH 400 trans. Weiand stealth manifold ( square bore ) summit 750 cfm HEI dist. with MSD http://www.summitracing.com/parts/MSD-8501/ 1-5/8 " full length headers CC H.P. double roller chain CC Retro HR lifters CC H.P rods PRW roller rockers 1.5 if it's for free its for me ! |
Looks like a good "torque" set-up. With the stock-length rods, you're limited on rpm. But it's not an issue if it won't see high rpm. Since you're pulling 4000lbs+ in weight, torque would be more important...especially with stock gearing (and possibly a stock converter). I like the set-up, even though 220 is a little big in my opinion. But with the last 406 I built, the one regret I had was not investing in better heads, like you did. With your heavy-car/stock gearing, your engine's a pretty good match. Just have to get rid of that stumble. In my opinion you should do it yourself. Anybody can pay someone else to do it...but what will they learn? Nothing. Do it yourself and you'll learn something you'll never forget. And it won't cost you anything but time (and some parts, of course).
F BIRD AND SUPERSPORT sound right. I learned one thing early on if it sounds like it makes sense its probably right. Jetting could be close on your carb but accel pump sounds like an issue. I am like F Bird I would tune it myself and make a handfull of passes out front of the house to get it dialed in. I am not to keen on other peoples work . If that carb is like a holley and memory serves me right ( been a while) the accel pump adjustment will actually work better with a small amount of travel on the lever before it moves the plunger at the diaphram. almost contrary to what you would deduct by looking at the way it works. Also timing and ported verses manifold vacuum for your advance mechanism is important. Take some time and write down the changes you make on a sheet of paper and review them as you go through the process. also make a note at the side as to wether it helped performance or hurt it.All part of the process. keeping track of where you came from can help you get where your going
Do your testing at the track! Besides the obvious, the trap speed is a good indication of HP. The money you save in tickets (God forbid you hurt someone else while doing your "testing") will be better spent for a test and tune day or two at your local strip.
My take on the dyno tune deal is, if you cannot work on the engine between passes, what's the point? Just an inertia-type "hamster wheel" will not tell you much about the real world performance. Even timing optimized on a dyno will not always equate to a usable setting, given the differences in air temps and ambient conditions- although they WILL show you what to get as close to as the real world will allow. In your case, the cam isn't too small, the ports are too big, IMO. |
| 350 engine overheating on dyno and since | betty55 | Engine | 12 | 05-26-2009 03:04 PM |
| Another Carb Tuning ?...TECH @ BG Help | Docs91RS | Engine | 2 | 05-26-2005 11:30 AM |
| Car missing while on Dyno? | FBody | Engine | 11 | 09-07-2004 10:17 AM |
| what first? advance curve or carb tuning? | dirtydave | Engine | 3 | 11-07-2003 04:42 PM |
| One Stop Dyno Tuning | ProPCMTuner | Engine | 1 | 12-09-2002 03:29 PM |
