Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Worthwhile upgrade?
Old 11-09-2012, 08:05 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
It seems Lunati has changes their catalog camshaft part numbers
Here is the new part number and their camshaft discription.
same cam different new part number:
Street Strip Solid Cam - Chevrolet Small Block 272/282
Product Description
Updated to be based on Lunati's new camshaft profiles. If you are looking for that extra performance and consistency needed to compete at the strip but you still want to be able to hit the local cruise-in, this line of Lunati Street/Strip camshafts are just what you are looking for. These Solid Flat Tappet camshafts have been computer designed to deliver added performance without being too harsh on valve train components.
Solid, fair idle. Excellent street/strip cam which will work as every day driver, very responsive. Needs 2400 RPM stall converter, headers, 10:1 compression ratio, and 3.55 or better gearing.
Advertised Duration (Int/Exh): 272/282
Duration @ .050 (Int/Exh): 238/248
Gross Valve Lift (Int/Exh): .485/.503
LSA/ICL: 112/108
Valve Lash (Int/Exh): .020/.022
RPM Range: 2000-6500
Includes: Cam Only
Part Number: 30120523
Previoius Part Number: 401A3LUN
Yes stock pushrod are fine. Yes stock type good long slot stamped steel rockers are fine.
Make sure the all the springs are shimed correctly. to 1.70". The 305 heads have deep exhaust spring seats that need
shims to compensate. get comp cams spring shim kit # 4753. ya it matters.
The lunati 73943 is a better spring than the comp 981 if you are willing.
Another really good spring choice is the Isky 235D (1.75" installed height)
Set the valve lash cold at .016 to .018 intake and .018-.020" exhaust. Its that easy.
You can get more intake valve lift by using a 1.6 ratio rocker on the intake side.
intake side only is best. Use the better springs for this. lengthen the pushrod slot in the head a bit, towards the rocker stud.
It would be nice if you drilled and roll pinned the rocker studs. it's easy to do and costs pennies to do. Screw in studs are not nessessary.
thats up to you.
This combo will work really really well.
