Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Worthwhile upgrade?
  #77 (permalink)
Old 11-12-2012, 04:07 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
You get the Y collector from Flowmaster and the pri/sec tube bends from DynoMax.
you can make your own custom slip in muffler baffle inserts that slide in/out of the 3" side pipe
allows you to adjust the volume and flow of the side pipe exhaust system. You can build better swapable insert baffles than you can buy. Remove the baffles for drag racing... empty 3" side pipe.
You don;t need to pay a shop to do what you can do better and for less $$$.
Once you get the header- exhaust system flow/scavenging efficiency up, you can make this car silly fast with a basic nitrous system.
10 second street ride for peanuts.
