The exhaust system needs work to make power and torque.
If you are good with a chop saw and a mig, its not that hard. A lot less work than the exhaust system on my bird was.
You can use those headers and the side pipes as a start. Some 180deg U bends and straights and the Y collectors and you are good to go. You got lots of room to work there. And all winter. If you are good at slash cutting and welding the pipe you can make your own Y collector transitions.
