Your present TC will have a lower stall from the hit at idle than it did w/the "wimpy" cam.
| The Following User Says Thank You to ap72 For This Useful Post: | ||
cobalt327 (11-12-2012) | ||
Am I really agreeing w/you on something? Weird feeling.
It wouldn't be my choice if he was to swap to decent aftermarket heads later though, so at least there's that.
Yu have three votes for the Lunati/UDharold street cam, now...
It is the right cam for you. (Windowing the block????.... I don't know where you,re getting with this. All these cams will have the same basic rpm limit. (with good springs) But will all run a little different. This one is the goldie-locks street cam for your Vette. It will have that just right feeling. The others need stuff you do not have. |
ya ya ya I get that but don;t get why He thinks thats going to happen.
Its the lowest price cam yet he says thats going to blow the budget. Its a slght bit milder than the Z-27 cam or the 201534 cam. ... But the Lunati 401A3Lun cam is the right cam for this car. Even if it costs a few pennies more to buy. I can show him how to run a high 10sec 1/4 mile with this cam, decent springs and nitrous, on his low buck 350 w junk yard ported 305 heads. (without windowing the block) But first he has to get the cam. A hyd cam will not do this. Both Howards and Bullet can supply this exact cam and probabily will beat Lunati's/Summit/Jeg's price, but you got to call them. He's going to screw this up..... Last edited by F-BIRD'88; 11-12-2012 at 09:58 AM. |
I agree the big cam solution does Not work without the heads to support it. Lunati is a good cam. They seem to be made a little better than most.
Most important factors in buying a cam are the simple things that get over looked.
Does this cam fit my engine aka. Does it work with coil bind and max lift guide clearence and springs installed. Springs worn out or bad. Valve opens 25% of diameter. Does it fit my application. |
If they're as bad as I think they might be even the 401A3 cam is too big. I'd like to see a better set of heads used, but it is what it is. |
The MPH from a drag strip pass will tell the tale of how well the heads are working.
Even a MPH with the cam he's got now. The nice thing about the Lunati cam is after the initial novelty has worn off,,, you can and will still enjoy driving the car, two years down the road, with this Lunati solid street cam in it. (as well as easily reach the performance goals and GLH) Its a sweet street cam. It will have a really sweet sound at idle. If his initial effort on these heads comes up short there is nothing stopping him from removing them, removing the valves and doing some more port work on them to sweeten them up. Most people don't go far enough when porting stock SBC heads. You cannot make them too big short of grinding right thru a port wall ,but you can overlook key areas deep in the ports. people tend to go for the easy to reach parts that looks impressive The port flange opening and the bowl under the valve. "pocket port" "port match" and buy into the oooo don't port too much, you'll screw them up, camp. This causes them to not get the whole port right. This is what limits the outcome. Not going far enough. You can fix that. Last edited by F-BIRD'88; 11-12-2012 at 11:08 AM. |
For the record, earlier in the summer I had run it on one of those gtech dyno things, I'm aware they aernt super accurate, but they repeatedly had me at 112mph and one at 114 which I know is horsesht and not accurate....but how close they are I don't know. 5mph high from what I can find on the interwebs from other users, which would put me near 107mph....still seems high....but till the track opens it is what it is. And yah, I know the headers are not ideal.....and will likely get changed at some point for an under car system, or a real hooker long tube sidepipes style.....
I have found lots of performance gains-and losses on many of my various cars, using it. You get a good window of what works and what don;t work, when trying different stuff out. The important relevant thing is it shows gains and losses in performance.i have A/B compared a Gtech to this. it was off and inconsistant. and 100 lbs is worth a tenth of a second. Last edited by F-BIRD'88; 11-12-2012 at 11:58 AM. |
| 68 nova project is a buick 430 worthwhile? | Dre68chevyII | Hotrodding Basics | 7 | 10-01-2010 12:30 PM |
| h4 upgrade | wrangler | Electrical | 5 | 10-01-2007 05:37 AM |
| Side draught carbs - worthwhile? | Neophyte | Engine | 1 | 10-07-2006 09:15 PM |
| what to upgrade on a 5.7 | pfmg | Engine | 4 | 03-11-2006 06:17 AM |
| McCulloch Supercharger? Worthwhile?? | Flathead Cosmo | Engine | 1 | 10-28-2003 09:06 PM |
