Worthwhile upgrade?
Went to pick up cam after work today, Dad building the young lads motor with him for an 85 monte and they changed direction to a Turbo motor midway through the build, I went to buy his new XE284 cam, but it turns out it a 292H, with lifters in box brand new, they offered it to me for 150$ as it wasn't the cam the lad thought it was. I told them I would sleep on it and call tommorow....I'm already hearing the 284 was missmatched based on the assumption my little 305 heads don't flow....but it seems the same rules for set up will apply, locked timing etc etc....so is it worth the cash and with 411's and. 3000 stall will it be significantly stronger then the stock converter and wee little lunati I have now? Have to let him know by lunch time tommorow so any input would be appreciated....
Is it for a 305 a 292h can be a really big cam on the small bore engines. It may also have way too much overlap for most turbo apps.
I love big cams but for small engine its not going to make any power under 3k rpm. Then it will only come alive long enough to run out of flow. Why 58 cc on a turbo motor. A 2.02 valve head with large chambers would be better. You can always turn up the boost its hard to turn down the compression. Race car/street car? |
I'm not entirely clear on what you are trying to say. Are you asking if you should use the 292H cam or keep what you have?
stock 305 heads can't flow enough to support even a 268xe cam so I wouldn't even consider the 292H, but people have made mismatched engines run okay in the past. If I were you I'd look at a MUCH smaller cam- around 215 duration at .050" if you're running stock 305 heads. |
Sorry for the confusion, 77vette, 350 with stock flattops, heavily ported 416 casting 305 heads, 194/150, performer rpm, 750 dp, 3000 stall, 411 gear...currently has a small lunati 214/224 , 443/465
Heads were ported using any and everything I could find on here from f-bird and he knows his stuff very well. The motor pulls very hard to 6000 as it sits currently. But I will be installing the converter in the spring and wanted more cam at the same time. The price seems really good for the 292 but I know the heads, even worked, aernt ideal, but is it still going to be a large improvement that's worth doing? |
And im getting the cam from a friend who purchased it, then decided against his n/a plan and is going Turbo, so he is selling the 292h new in its box....
I just can't see using a cam with that much overlap on a budget turbo build. You'd be better off with the stocker.
That lunati may be the best choice. What's the lsa?
Yeah better heads would be in order for that cam. Its a much bigger cam than you have right now. 3k stall and compression are good enough to run the cam if the flow is ok it will still make some power but always will be under potential. 210cc intake ports with 2.02 valves would carry you into the 6k rpm alot better. A smaller cam would run alot smoother and still make about the same power in the end.
Dont go to small be aware of the dcr when selecting a cam for that combo compression must be around 11:1. A small cam will make it knock bad with those heads. |
The Xe284H-10 is a better cam for your purpose. As far as being a good match to your combo stop
listening to people who no nothing about cams or ported 305 heads. Don't ask people on the internet how much power you will make. They don;t know. That what they make dynos and race tracks for. The 292H magnum is not a bad cam. but....Id rather see you use a better solid lifter cam if you want to go that big on the cam. It will work a lot better. Don;t be intimidated by street solid lifter cams. They are not hard ro deal with at all. Your friend is not the only guy with a cam for sale. You can buy a new cam for $150. In a hyd the XE284H-10 would have been a good choice. Yes your ported big valve 305 heads will work very well with it . If you did a decent job on porting them they actually flow pretty good. The only way to know how thye turned out os to run it down the track, stick it on a dyno or flow test the cylinder heads. You are on your way to a good combo for the street for your vette. Don;t fuggg it all up now. A Isky Z-27 cam would work very well. #201027. Another cam I like even better for this combo is the Lunati 401A3LUN cam. A nice street solid cam that will run nicer than the comp 292H. You will like it better overall. good with your ported heads, good wiht the 3/4 shorty headers good with the 3000 stall and 4.11's. The comp 292H needs a higher stall converter. 3500++. Thats what I would do if not the Comp XE284H-10 cam. The comp Xe284H-10 cam is the biggest I would go with the 3000 stall converter. http://www.lunatipower.com/CamSpecCa...umber=401A3LUN Grind number 01-UF15-UF16-12 part number 401A3LUN 272-282 238-248 @.050" .485" .503" 112LSA .020" lash. use a lunati 73943 valve spring. (the comp 981's will work with this cam if shimed correctly. Ya this matters.) These "NEW" Lunati cams are UD Harold/Ultradyne Cam designs. Known for being really good cams. This is a sweet street cam for your Vette. Based on your picture you have dished pistons. Install the 305 Heads with a felpro 1094 steel shim head gasket to get the compression ratio right. Install clean and dry on a clean dry block surface. ya this matters. |
So a hydraulic cam with 244º duration is in the same ballpark as a solid cam with 238º duration? yea right. A comparable hydraulic cam would have about 225º duration which is used with fully ported 305 heads would actually be about right. So yes, the 401A3LUN cam would be a pretty good match (if the heads are ported)- the 292H cam isn't even close. BTW, I'm sure F-bird knows this, but for those that don't you can't compare hydraulic and solid cams directly at 0.050" for the fact that solid cams run lash, for your typical .020" lash you need to subtract around 12 degrees to get an equal hydraulic duration- for more lash you subtract more duration for less lash you subtract less. |
It seems Lunati has changes their catalog camshaft part numbers
Here is the new part number and their camshaft discription. same cam different new part number: Street Strip Solid Cam - Chevrolet Small Block 272/282 Product Description Updated to be based on Lunati's new camshaft profiles. If you are looking for that extra performance and consistency needed to compete at the strip but you still want to be able to hit the local cruise-in, this line of Lunati Street/Strip camshafts are just what you are looking for. These Solid Flat Tappet camshafts have been computer designed to deliver added performance without being too harsh on valve train components. Solid, fair idle. Excellent street/strip cam which will work as every day driver, very responsive. Needs 2400 RPM stall converter, headers, 10:1 compression ratio, and 3.55 or better gearing. Advertised Duration (Int/Exh): 272/282 Duration @ .050 (Int/Exh): 238/248 Gross Valve Lift (Int/Exh): .485/.503 LSA/ICL: 112/108 Valve Lash (Int/Exh): .020/.022 RPM Range: 2000-6500 Includes: Cam Only Part Number: 30120523 Previoius Part Number: 401A3LUN Yes stock pushrod are fine. Yes stock type good long slot stamped steel rockers are fine. Make sure the all the springs are shimed correctly. to 1.70". The 305 heads have deep exhaust spring seats that need shims to compensate. get comp cams spring shim kit # 4753. ya it matters. The lunati 73943 is a better spring than the comp 981 if you are willing. Another really good spring choice is the Isky 235D (1.75" installed height) Set the valve lash cold at .016 to .018 intake and .018-.020" exhaust. Its that easy. You can get more intake valve lift by using a 1.6 ratio rocker on the intake side. intake side only is best. Use the better springs for this. lengthen the pushrod slot in the head a bit, towards the rocker stud. It would be nice if you drilled and roll pinned the rocker studs. it's easy to do and costs pennies to do. Screw in studs are not nessessary. thats up to you. This combo will work really really well. |
| All times are GMT -6. The time now is 11:18 PM. |
