would this combo actually make this much power - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-13-2008, 04:45 PM
ericnova72's Avatar
More for Less Racer
If you don't know how to get the "minor details" right, and many people don't(or don't even know what they are), then ScoT is pretty close, maybe 20 HP overboard.
That's the difference between "engine builders" and "engine assemblers". Assemblers can get it together , but usually only Builders can make the big power. F-Bird, I'm sure you already know this
  #17 (permalink)
Old 07-13-2008, 05:16 PM
72 grabber 51F-1 65 chevystang
I thought about building a 347 stroker with afr 185's and about 12 to 1 compression. If it got about 450hp I would be more than satisfied
  #18 (permalink)
Old 07-13-2008, 06:24 PM
ive seen quite a few N/A 347s dyno and they are usually quite dissapointing.
Even some of the well put together ones.
I know of a local 306 running around with AFR heads a good intake setup and a very healthy solid roller.
It makes about 300whp through a T5 and a 8.8. Pretty sad if you nask me.
  #19 (permalink)
Old 07-13-2008, 06:43 PM
How many people would use an already running short block?
or dingle ball one in their garage to build an engine?
How many people insist that torque plate honing helps 20-30 hp?
How many people insist that fuzz brushing cylinder walls helps 10 hp?
How many people insist that low tension rings adds 10+ hp?
How many people insist that full circle rings adds 10-20 hp?
How many people insist that if you have dome pistons that contouring helps 20-30 hp?
How many people would use a "jessel" and find exactly what the engine wants?
For the arithmetic challenged
455 x 90% = 409.5
That's 45, not 80 hp
Generalizations are just that, generalizations.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
what compression will this combo make?? 70ChvyNova Engine 21 01-03-2007 05:40 AM
how much power should this make? dboyett38666 Engine 2 03-13-2006 07:44 AM
which would make the most power?? joe28boxer Engine 0 10-05-2003 08:19 AM
