Who's gonna argue with a track record like theirs? |
I read somewhere that a stock 302 block can only handle 600hp but 500 would definately be safer. 751hp surely is a aftermarket block which means big bucks.
I have used AFRs several times before because I always heard they were the best, but I was ALWAYS disappointed in the performance. Their flow to port volume ratios aren't anything to write home about, and they tend to inflate flow numbers. Put them on a bench yourself and you'll probably find they don't flow nearly as much as AFR claims.
Having toured their facility several times, I can see why. Their CNC machine is older than dirt, and their port models are getting old; as in last updated in the early 90s for most traditional blocks from what I understand. AFRs are fine heads and they perform great, but I think they make most of their money by publishing big claims and hoping that the person who buys it doesn't actually know what HP feels like. They seem a bit "boutique" to me; all claim and not much game. One of the sets I had, the CNC machine dug way too fast and too deep into one side of the chamber and totally missed the other side. The fact that they screwed up is human, but to miss it during inspection, or to actively send it to me anyway knowing it was messed up just turned my stomach. Any time you see over 2 hp per CI in a stroker block, you can pretty much bet you're looking at a shortblock that is in the 5-figure range. ... and, no, it won't hold together, nor will it make any power until 5000 rpm. And it will idle at 2000. Put it this way... I'm currently building an LT1 383 stroker. For $2700 I could have AFR 180s... BUT, instead I'm going to spend $1800 on custom CNC ported LT1 heads that flow as much actual air (not advertised) as the AFR 180s, and that 18 bills also gets me titanium retainers, pacalloy beehive springs, 2.02/1.6 valves, and an F1-spec TIR < .00012" valvejob with Manley stainless ProFlos AND (the big one) my choice of a custom made, hardened billet roller cam. I strongly suggest looking to other avenues. If you're rich and you want the prestige of AFR's name to wow the guys at the cruise-in, go for it. If you want to go fast and your name isn't Midas, look elsewhere. Last edited by curtis73; 07-11-2008 at 11:52 PM. |
The AFR 180's are for your grandma's car, I'm talkin' real manly heads in the 210cc+ range. The two sets we tested on a SF-600 bench were within
1 1/2% of what AFR said they were. |
sam-missle |
flow numbers are just a number, you can make any head flow great numbers but will it make your car faster? when you get your LT1 heads compare them to the AFR'S. let us know if they actually flow the same with the same port velocity. i think you will be suprised, and find that the AFR is a far better head. sam-missle |
The big (for a 650 demon carb) jets indicates the test was done with cold, dense air (winter). Probabily much colder than 60F-70F. Cold, dense, winter air makes more power than the SAE dyno test standard spec. Probabily raw uncorrected numbers.
Stock Ford 302 blocks will hold together for awhile with 450 hp, push it to 500 hp and expect it to split right in half down the lifter gallery. I wouldn't push a stock 302 block more than 400 hp if you want any kind of life out of the engine. This is why Ford Motorsports makes the beefed up 302 blocks and World makes a even better 302 block. It is very easy to make too much hp for a stock 302 and have it spit parts everywhere.
The Lt1 owner is completely right. AFR isnt what it used to be. They used to be awesome but when they went to make their LT1 heads they just transfered over a slightly modified SBC. The LTX AFRS blow. Especially for the money.
The onyl LTX AFRs worth buying are the 227cc and only the guys doing all out builds are buying those and about 99% of them are having them shipped out for more port work. A ported stock casting is a far better head for the money for the LTx crowd, and flow numbers dont mean jack. People like Advanced Induction are doing good work with ported stock castings. Hows 500whp out of a 355 on an LTX manifold sound? Go to advancedinduction.com And the other ones, the LT4 raised runner AFRs are apparently a huge ***** and ALOT of money to get setup properly. I have seen some pretty weak things from AFR lately and there are alot better choices out there. Their LSX castings are pretty darn good but people are doing the same things with ported 5.3 heads. About the only good things I have to say are their 205cc LSx heads have some great mid lift numbers. |
Opti... thats the exact porter I'm using; advanced induction. Nice heads, and I agree. Their published timeslips tell the truth; power and torque under the curve is what wins the race.
Oh... and on the topic of customer service, those AFRs that I mentioned with the CNC cut too deep on one side of the chamber and untouched on the other? They refused to accept them for return. I had to drive the heads up there, show them what was wrong, and then they offered to refund me minus a 30% restocking fee - which brings up two very murky things. Either they intended on putting them back on the shelf for some other poor soul, or they were just going to junk them and soak me for 30%. I had to get a lawyer, so when it comes to customer service? Don't ask ME about it. |
Tany Mamo is a good guy and really knows his stuff but I think when it comes to the LTX and GEN 1 stuff, they are just resting on their laurels.
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| what compression will this combo make?? | 70ChvyNova | Engine | 21 | 01-03-2007 04:40 AM |
| how much power should this make? | dboyett38666 | Engine | 2 | 03-13-2006 06:44 AM |
| which would make the most power?? | joe28boxer | Engine | 0 | 10-05-2003 07:19 AM |
