Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Would Every Cylinder's Rings Be Bad???
Old 07-02-2008, 08:10 AM
71gtx 71gtx is offline
Last journal entry: Rear End Disassembly
Originally Posted by n-gin
Any thing will fire off at least 80 psi. My lawn mower is 70psi. .
Are you taking the compression reading at Wide open throttle or with the throttle closed?
Wide open throttle. She'll fire, but bogs horribly until you reach about 5000 rpm. I took coils, ignition modules, carbs, battery off of same style running bike and get the same results.
