Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Would Every Cylinder's Rings Be Bad???
Old 07-02-2008, 01:54 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Make sure the positive wire is on the correct side of the "+"coil, as it will cause a miss at high rpm, as well as incorrect spark plug wires.
Point type is solid core wires.
Luv the smell of NITRO in the morning.
