would increasing the compression ratio on an engine with worn rings increase oil burn - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2012, 05:48 PM
I just changed the cylinder heads on my sbc 350 from 76cc chambers to 58cc, big time compression boost with the flat tops pistons that were already inside
anywho i never burned oil before, but now it's burning a bit of oil out of the passenger side tailpipe, the same side where i noticed the rings for one of the pistons were not in too good a shape
so my question is, would me raising the compression ratio on my engine increase the strain on already worn piston rings and force it to burn oil ?
or is there something wrong with the new machined heads i bought ? because it never burned any oil before
Old 07-02-2012, 05:55 PM
Greg T's Avatar
www.krusinklassics.net
The short answer is yes. Increased compression= increased cylinder pressures = increased blowby.
Old 07-02-2012, 06:02 PM
I took of the heads and found forged pistons, cast would of probably of hugged the cylinder walls better when they heated up and stopped the blowby
it's smoking ever so slightly out of 1 tailpipe so whatever, thanks man
Old 07-02-2012, 07:09 PM
Originally Posted by F-BIRD'88 View Post
Intake manifold gasket vacuum leak.
worn valve guides. bad or missing valve seal.
Oil migrating up the PCV hose into the intake manifold.
Valve cover breather/pcv oil baffling. (aftermarket valve covers)
it's a new pair of cylinder heads with new seals and valve guides
i thought it was the pcv but it's only smoking out of 1 of the two tail pipes, i removed the valve and plugged the vacuum port on the carb but it still smoked
SAATR's Avatar
Last wiki edit: Header design
Last journal entry: And still more pics...
Of course, blow-by doesn't automatically mean oil consumption. Blow-by is fuel, air, and combustion gasses getting by the compression rings, and doesn't necessitate that excess oil is getting by the rings going the opposite way. F-BIRD suggested quite a few areas where oil consumption can stem from, especially on a new-to-you set of cylinder heads. It's worth checking out before you automatically fault the short block.
Oversize rings for worn cylinders OK? offroadn Engine 11 11-18-2011 03:22 PM
74 Caprice - 400 SBC - Valve seals or worn rings ? (Video) Calderone Engine 2 01-17-2011 10:59 PM
Thinner head gasket to increase compression ratio? newchevyman Engine 3 05-04-2004 11:53 PM
Compression and oil rings. TVR383 Engine 4 03-27-2004 09:05 PM
Increasing Compression meschnebly Engine 14 08-13-2003 06:56 AM
