Would like a stronger sbc 350 than stock heads. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2005, 11:13 AM
Hey guys, I'm a novice and could use some advice. I've got a 69' sbc 350 - 300 horse Corvette. I've got an Edelbrock Performer intake, 600 Q-jet with Hooker Headers. I would like to up the horse power by changing heads. Should I look for stock 350 HP heads, go aftermarket and exactly what spec's do I need for a little more excitement.
Old 11-11-2005, 11:49 AM
firestone's Avatar
http://teamrfc.gospelcom.net
What is the maximum amount of money you have to spend on a set of assembeled heads?
Adam
Old 11-11-2005, 12:29 PM
Here is what I would put on it.
http://store.summitracing.com/defaul...h.asp&N=400333
Old 11-11-2005, 01:41 PM
DoubleVision's Avatar
If your engine is the factory engine and has the original heads it should have 041 castings or 186 or the like, these heads will easily make your 50 extra horses goal with some bowl porting and a cam swap from the factory cam. The heads that came on the higher horsepower factory small blocks are the same heads, they only had bigger valves. check the casting numbers on your heads and go from there. You can check your numbers here:
http://www.mortec.com/castnum.htm
If your still running a points ignition, dump it and get a pertronix conversion unit, tune it up with the best components you can buy, spiral core plug wires and etc. If your still running the factory cam you`ll see a nice power gain by swapping to a more modern computer designed cam, the old cams are stone age by comparision. You can call the cam company of your choice, tell them your engine, your car, and your mods, and they`ll recommend the right cam for you. You already have a good platform, you just need to add the right components to make it come to life.
Old 11-11-2005, 09:46 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I would go Edelbrock or better yet for a few more bucks AFR.
Old 11-12-2005, 01:49 PM
fast68's Avatar
likes chevy trucks & boobies
i have a set of 487x heads untouched unmolested completely stock still
very good shape,
i have no use for them, they need a good new home, are complete and on running driving engine, no issues at all with them, clean and paint them and run them, threy are off a 71 nova original and are dated such
if youre on budget then good hi perf stock castings would be the way to go, they are around and theres a few good castings like these that are good flowing,
i run 493's right now, also off a 71 car and dated same, with my 272/282 cam, untouched ones too
breathes great at high RPM, surprised me, but you gotta rally get up into the powerband to see how well it does,
the 487x would breathe better than the 493 im sure,
but i dont feel like swapping,
not right now
good luck
Old 11-12-2005, 03:22 PM
steve t's Avatar
ex biker, now hotrodder
what is differn between 487x and just 487 no x heads
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Mild 350 SBC buildup 79 Malibu327 Engine 6 09-21-2004 08:56 PM
sbc 350 stock heads!! help? inkfixer73 Engine 3 08-12-2003 11:50 PM
How many ponies will 350 heads make me have chevyteen17 Engine 6 04-16-2003 01:14 PM
