Would a oil cooler kit be needed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2012, 08:34 PM
billonwheels's Avatar
Last journal entry: On the Road
So my 455 bored 30 over is being put together. The engine came out of a boat and the oil filter had been relocated. Would a oil cooler kit be a good idea since my engine's already setup for the relocation? I've heard that after these engines been bored over they can tend to get hotter than most.
ID:	63029   Click image for larger version
Old 02-16-2012, 09:18 PM
4 Jaw Chuck's Avatar
It can never hurt but I doubt it's necessary unless your road racing on a track. A large capacity multi row radiator would be a wiser investment for daily use and likely achieve the extra cooling you will require idling in traffic on a hot day.
— Han Solo
Old 02-16-2012, 09:50 PM
The boat had a relocated oil filter so it could changed. Your engine is designed to be cooled by its cooling system. That being said...
What he said about the radiator. If you have an auto trans, make sure THAT has a big oil cooler and that it is plumbed through the radiator. Then you'll be good to go. Do a little research if that doesn't make sense to you.
Long live the 455.
Old 02-17-2012, 03:15 AM
Yea I'm going with an Aluminum Radiator for my cooling needs. Getting my TH400 Trans. rebuilt adding a shift kit to it. Was thinking a oil cooler couldn't hurt.....
yes Long live the 455...
Old 02-17-2012, 08:34 PM
bigdog7373's Avatar
Of course it's fast
You could get a a larger capacity oil pan... More oil=cooler oil
Old 02-17-2012, 09:06 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
if you are going to use the relocated filter
it will act as a cooler, if put out front, where it can get fresh air
using a trans cooler for a gas cooler? biohazard_81c10 Hotrodding Basics 2 09-05-2011 02:09 PM
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 09:10 AM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
Oil Cooler jrm123180 Engine 5 08-27-2004 10:22 PM
Oil Cooler?? Dave E Shank Engine 7 11-01-2002 08:00 AM
