Would it be ok to use 5W-30 in a small block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2012, 11:01 AM
Banned User
Do you think it would be ok to use 5w-30 in a stock small block?
The reason i'm asking is because i can't find 10W-30(flat lifters) in the store and would rather not do mail-order, although i will if nessesary.
Old 08-19-2012, 11:12 AM
LATECH's Avatar
5W 30 will be fine. Lots of myths about motor oil. Like 5 is the cold weight viscosity....wrong.
The first number is a reference to the cold pourability/flowability of the oil.It references the deviation of the viscosity (30) when the oil is cold.
The lower the number the closer it stays to its sae 30 rating when colder.
This means that the oil pressure build quicker(slightly) when cold, by using the 5w 30 than the 10w 30 .
The best way to ensure consistent viscosity and protect against engine wear is to run a synthetic.
Fact is stranger than Fiction
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 08:36 PM
small block to big block swap in a 91 camaro help! Greg O Sandsten Engine 6 11-02-2010 12:02 PM
small cam's for chevy small block's 70 nova Engine 8 06-14-2003 12:02 PM
are 1 5/8 long tubes too small for a 414 ci small block? tony350ss Engine 8 03-17-2003 12:45 PM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 08:06 AM
