Which would be preferred for a 1927 Model T: Manual or Automatic transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2006, 03:16 PM
Newbie post here, but after digging around, I think I'll be spending a lot of time here while I work on my car.
Anyways, I have a 1927 Ford Model T roadster with the original chasis and a title that's about to go under the knife, but one of the first things I need to decide on is whether I go with a standard or automatic transmission. I've always thought a car like this should be manual, but there's always the negatives of not having power steering, a bit more complicated of a set up etc.
What do you guys think? Should I drop a manual or automatic trans in this car? Thanks for the advice.
Old 02-13-2006, 03:25 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
auto with a shift kit is what ive always thought would be better for a very light car like a T ...
t's dont have much space, so an extra pedal and a shifter that (in 1st and 2nd) is going to reduce your space even more ... eeeh ... i get almost the same amount of joy slap shifting an auto ...
Old 02-13-2006, 04:19 PM
jalopy45's Avatar
First go-a-round, build a solid frame and go with an automatic. The car will be light enough you won't need more than manual steering. You can always change to a manual later if you want to row through the gears.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 02-13-2006, 06:27 PM
As a moderator here, I would like to
WELCOME YOU HERE...
Lots of very knowledgeable folks here.....
Most early cars have a automatic transmission nowadays.......it is vastly easier to do. Clutch linkage, another pedal and then the shifter.......all complicate the vehicle and can compromise the FUN....
IF....you are going to use a Small Block Ford......I suggest a early one....with the 5 bolt bell housing....it is a lot more narrow in that area......which is a good thing.....
Old 02-14-2006, 05:18 PM
T buckets rule
Welcome here. This is a great site and a great bunch of guys and a wealth of info. Don't leave this site but come look at the National T Bucket Alliance site. A ton of info over there. Nothing but T Buckets.
http://www.nationaltbucketalliance.com/bb/
Old 02-17-2006, 08:39 AM
Thanks for all the advice, this is a solid forum. So the general consensus is automatic eh?
I'm actually going to be putting a 327 chevy in it. This is a car I got from my Dad. We intended on restoring it together, but he passed away a couple years ago. It's kind of a duty of mine to finish the car, however, I'm having someone who knows what they're doing help me with it. I'm pretty much a flash light holder at this point that wants to learn the ins and outs in the process. I remember ripping around in it about twelve years ago with my Dad and it was super fast, but it's always needed a full restoration. Nows the time as I really want to be able to enjoy it while I'm still young. (no disrespect to some of the older members So I'm going to be looking at a lot of other cars for ideas. Any advice would be appreciated. You guys will officially become my mentors for this project. Thanks!
"49" Ford Business Coupe Custom Transmission Swap standard to late model Automatic Rockin Rick Transmission - Rearend 4 10-14-2003 02:40 PM
Manual Transmission on a 1985 Olds? Andrew7dg Transmission - Rearend 0 07-25-2002 09:46 PM
Model A - Automatic to Manual Trans resolution2 Transmission - Rearend 2 06-05-2002 08:42 PM
30 Model Manual Trans conversion resolution2 Hotrodders' Lounge 0 05-28-2002 09:25 AM
How strong is a TH 350 Automatic Transmission bigjoedo Transmission - Rearend 2 04-04-2002 06:22 AM
