Would roller lifters work without a roller cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2009, 08:23 PM
Ive been wondering for a while if roller lifters would work without a roller cam. What cam would the roller lifters work best with besides a roller cam, if they work at all? Thanks, demon.
Old 11-07-2009, 08:33 PM
ericnova72's Avatar
More for Less Racer
No you cannot use roller lifters on a non-roller cam, they are incompatable for several reasons beyond just the lobe shape, not the least of which is the valve timing events will come out incorrect by an extremely large margin. The engine will run terrible, followed a short time later by lifter or cam failure due to their incompatability.
Old 11-07-2009, 08:38 PM
That about answered it. Thank you for the quick reply!
Old 11-07-2009, 08:39 PM
You probably just saved my motor, thanks.
Old 11-08-2009, 04:44 AM
Check with Howard's for retro fit roller setups.
Shane
350 cid gm engine roller cam lifters problem rbp Engine 2 07-25-2009 09:04 PM
Adjusting lifters, Hydraulic roller cam Sinister Engine 5 04-30-2009 05:13 AM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 04:12 PM
BBC gen 6 roller cam! Studebaker Engine 1 01-04-2008 07:13 AM
Roller Lifters - standard cam ckucia Engine 27 01-27-2006 01:05 PM
