Would these be a good set of heads for my application? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-02-2013, 08:07 AM
Originally Posted by snakebit68 View Post
One thing to consider...if you're running 9.5 to 1 compression currently...would these heads have a smaller combustion chamber and increase your compression to a degree that running on pump gas is no longer possible? I have no experience on Patriot heads...but from what I've read there are some complaints about oil return holes and machining on the gasket surfaces that causes some sealing problems. In otherwords, the head gaskets and intake gaskets leak. But, this is only what I've read and have no personal experience. Just keep in mind that if a deal sounds too good to be true...it usually is.
No thats my bad i calculated it 882's with 64cc chamber instead of 76. So I think with my new heads im going to be at about 9.75:1 compression.
  #17 (permalink)
Old 02-02-2013, 08:09 AM
Originally Posted by 67L View Post
I thought the 268 cams were fine with factory stall...unless you are racing. As for the carb: the 600 will be a restriction. I just finished a 383 build. 422hp at 5200rpms...463 lbs at 4300rpms...but 1.6" vacuum at WOT so it was carb limited. 650 or 750 will be best. If you use an Edelbrock 600 cfm, go with 104 secondaries, springs that open at 7" vacuum and change the metering rods. Otherwise you will be lean above 4000 rpms
I used the holley carb selector tool and it said for my motor (Mild street) I should use a 600cfm vac sec. But i am thinking about using a 650 DP. I think 750 would be too much carb for my motor and the throttle response would suffer as a result.
  #18 (permalink)
Old 02-02-2013, 08:21 AM
vinniekq2's Avatar
5500 rpm is too low for the chip.I use a 6 k chip to soften the engine as the tires break loose in first and second. Maybe put a 6400 rpm chip in there before you install the ignition. I like the little 650 DP,it will limit top end a lot.If your negine is way below 375 HP then use the 650. I prefer the 750
  #19 (permalink)
Old 02-02-2013, 08:33 AM
heads
I like the 650 DP as well. Vinniekq's right about it limiting top end though...especially a 600. 600's really only fuction well on a bone stock 350. Why did you set your rev limiter to 5500? I set my shift light at 7000 and my rev limiter at 7500. Vinnie...you seem to be on top of every thread in here. Glad to know you're around and taking time to help everyone out in here. You seem to know your stuff.
  #20 (permalink)
Old 02-02-2013, 08:40 AM
lol i thought my motor would never be able to rev past 5500rpm.
  #21 (permalink)
Old 02-02-2013, 08:47 AM
vinniekq2's Avatar
Logan,you dont set the rev limiter at the red line or shift point,you set it a little higher as a safety. If you miss a shift/break a driveline part/lose traction,the rev limiter stops the engine from turning insideout.
snakebit, I have a little too much spare time atm,lol.
off to work today though.
I was going to PM you about your truck engine,I think we have similar parts in our engines,,,
The Following User Says Thank You to vinniekq2 For This Useful Post:
logan1 (02-02-2013)
  #22 (permalink)
Old 02-02-2013, 08:48 AM
heads
You know best where your engine ceases to make power...if thats 5500 then set your rev limiter at 6000 or 6200
  #23 (permalink)
Old 02-02-2013, 09:01 AM
heads
Yeah Vinnie, I think you're probably right. I'm new to this forum and would love to talk shop with you about our engines and cars. I was curious what year your car is? What engine you running? Throw them details at me brother. Maybe I can steal a secret or two from you. LOL
  #24 (permalink)
Old 02-02-2013, 09:13 AM
Got it...I'll get another chip and bump the rev limit up to 6500. Considering this motor is going into a 70 Datsun 240Z that weighs in at 2300lbs; Im expecting a lot of traction lose.
  #25 (permalink)
Old 02-02-2013, 09:35 AM
Guys now that i have a head that can take a .575 lift would it be beneficial to upgrade the Hydraulic flat tappet cam? Would a comp cam 12-214-4 be a good choice? or is there a better option that will give me more power while keeping the car streetable. I would like to go as aggressive as possible but this is a 70% street car, 30% autocross/strip. I would also like to have enough vac to run power brakes and vac advance on my distributor. I have T5 mustang transmission and i have 4:11 gears in my diff.
http://www.summitracing.com/parts/cc...make/chevrolet
Camshaft, Hydraulic Flat Tappet, Advertised Duration 305/305, Lift .525/.525, Chevy, Small Block
  #26 (permalink)
Old 02-02-2013, 09:46 AM
logan1, when you start assembling your engine check your deck clearance. Measure from the top of the piston at TDC to deck of the block. If it has not been milled it will probably be .025. You can use a straight edge and a set of feeler gauges to get your measurement. measure from front to back, parallel with the piston pin. Get a set of these head gaskets to set the quench at .040 if your deck clearance is .025. Fel-Pro Performance Head Gaskets Q1094 - SummitRacing.com.
The Following User Says Thank You to cdminter59 For This Useful Post:
logan1 (02-02-2013)
  #27 (permalink)
Old 02-02-2013, 09:49 AM
Kool I'll be sure to do that. Also coincidentally the spec sheet for the patriot heads recommends the Fel-pro 1004 or 1094 head gaskets.
  #28 (permalink)
Old 02-02-2013, 02:38 PM
Well i called Comp and asked for help picking a cam. They told be the biggest cam i could get and still have power brakes would be a XE274H.
  #29 (permalink)
Old 02-02-2013, 03:49 PM
heads
Thats true...however, you can easily add a vacuum reserve. It simply stores vacuum for when you're at idle. Its inexpensive, effective and allows you to run a fairly large cam without concern. Check Summit Racing, I think the run like $45.00. Its just a dang coffee can with vacuum line in and vacuum line out.
The Following User Says Thank You to snakebit68 For This Useful Post:
logan1 (02-02-2013)
  #30 (permalink)
Old 02-02-2013, 07:50 PM
vinniekq2's Avatar
COMP Cams Magnum Hydraulic Camshafts 12-214-4 - SummitRacing.com
I wouldnt use that cam for anything.
If you want that much cam,buy a roller. If a roller is too expensive then use a solid flat tappet.
300 advertised duration flat tapped cams are just not great,they sound like 700 hp and generate less than a moderate solid
Is this a good set of heads? Zeder Engine 20 12-08-2004 04:17 PM
Is this set of heads any good? batman09 Engine 3 09-22-2004 10:19 AM
Good Set of heads? Camaro2Fast4u Engine 5 07-10-2003 08:34 AM
Where to buy good set of used cylinder heads.. chevyteen17 Engine 4 03-28-2003 05:01 AM
For the price of new heads would it not be better to refurbish a good set of old ones stonedchihuahua Engine 52 12-26-2002 12:38 PM
