Would these be a good set of heads for my application? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-02-2013, 09:49 AM
Originally Posted by cdminter59 View Post
logan1, when you start assembling your engine check your deck clearance. Measure from the top of the piston at TDC to deck of the block. If it has not been milled it will probably be .025. You can use a straight edge and a set of feeler gauges to get your measurement. measure from front to back, parallel with the piston pin. Get a set of these head gaskets to set the quench at .040 if your deck clearance is .025. Fel-Pro Performance Head Gaskets Q1094 - SummitRacing.com.
Kool I'll be sure to do that. Also coincidentally the spec sheet for the patriot heads recommends the Fel-pro 1004 or 1094 head gaskets.
  #32 (permalink)
Old 02-02-2013, 02:38 PM
Well i called Comp and asked for help picking a cam. They told be the biggest cam i could get and still have power brakes would be a XE274H.
  #33 (permalink)
Old 02-02-2013, 03:49 PM
heads
Thats true...however, you can easily add a vacuum reserve. It simply stores vacuum for when you're at idle. Its inexpensive, effective and allows you to run a fairly large cam without concern. Check Summit Racing, I think the run like $45.00. Its just a dang coffee can with vacuum line in and vacuum line out.
The Following User Says Thank You to snakebit68 For This Useful Post:
logan1 (02-02-2013)
  #34 (permalink)
Old 02-02-2013, 07:50 PM
vinniekq2's Avatar
Originally Posted by logan1 View Post
Guys now that i have a head that can take a .575 lift would it be beneficial to upgrade the Hydraulic flat tappet cam? Would a comp cam 12-214-4 be a good choice? or is there a better option that will give me more power while keeping the car streetable. I would like to go as aggressive as possible but this is a 70% street car, 30% autocross/strip. I would also like to have enough vac to run power brakes and vac advance on my distributor. I have T5 mustang transmission and i have 4:11 gears in my diff.
COMP Cams Magnum Hydraulic Camshafts 12-214-4 - SummitRacing.com
Camshaft, Hydraulic Flat Tappet, Advertised Duration 305/305, Lift .525/.525, Chevy, Small Block
I wouldnt use that cam for anything.
If you want that much cam,buy a roller. If a roller is too expensive then use a solid flat tappet.
300 advertised duration flat tapped cams are just not great,they sound like 700 hp and generate less than a moderate solid
  #35 (permalink)
Old 02-02-2013, 08:25 PM
Yes the roller cam is too expensive for me at this time. To switch to a solid flat tappet cam would i need to change anything other than the cam and lifters?
  #36 (permalink)
Old 02-02-2013, 08:28 PM
Also you thoughts on this hydro flat tappet cam:
286/286, Lift .490/.490, Chevy,
COMP Cams Magnum Hydraulic Camshafts 12-326-4 - SummitRacing.com
  #37 (permalink)
Old 02-02-2013, 08:44 PM
also considering this cam:
292H-10
292/292, Lift .501/.501, Chevy,
COMP Cams Magnum Hydraulic Camshafts 12-213-3 - SummitRacing.com
Just watched a video of this cam on youtube and it sounds amazing.
https://www.youtube.com/watch?v=lCEVGG8QQr0
  #38 (permalink)
Old 02-02-2013, 08:46 PM
vinniekq2's Avatar
solid Vs hydraulic
that cam would likely be decent.
I really do not like hydraulic flat tappet cams.The solid cams with the same grind as the flat tappet cam usually perform a fair bit better.
most people prefer hydraulic as they do not require adjustments. The solid usually idles smoother and revs a little higher
  #39 (permalink)
Old 02-15-2013, 01:58 PM
Is it a good idea to run a gear drive as oppose to the standard chain drive? There is one for sale in CL and i was wondering what the advantage of running it were.
Gear Drive Pete Jackson Type
  #40 (permalink)
Old 02-15-2013, 02:17 PM
F-BIRD'88's Avatar
Yada Yada Yada
do not use a gear drive. ever. a great way to give up 25 to 40 horsepower on a SBC.
If you rev up the engine higher than 6000 rpm the solid lifter cam has a advantage
in both power, torque and rpm limit. They typically out perform a hyd cam.
pick a solid lifter cam with about 6 deg more duration @.050" than a hyd cams .050" duration to account for the solid lifters valve lash.
If you like rpm, power and torque the solid lifter cam is better.
Setting the valve lash and maintaining the valve lash thru periodic valve lash maintanice
is pain free when you have a good valve lash adjustment method. They are not a pain at all to set and maintain.
I like the Isky solid flat tappet cams for street strip stuff.
They always work real well.
have a look
ISKY Racing Cams - Do It Right. Race with the Legend. Camshafts, Connecting Rods, Valve Springs, Lifters
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
logan1 (02-15-2013)
  #41 (permalink)
Old 02-15-2013, 02:26 PM
F-BIRD'88's Avatar
Yada Yada Yada
AS for power brakes and mainifold vacuum and cam selection you can use a cam that is bigger than
the XE274H-10 cam. The engine set up matters. A axillary electric vacuum pump helps as well as a add on vacuum reservoir.
I do and have run much bigger cams than this and power brakes without the aid of either, thou.
The engine set up is critical and makes all the difference. (torque converter,,, ignition timing curve)
First thing to do is check for power brake vacuum diaphram leaks.
Any all of the ready made bolt on street rod "block hugger" shorty ehaders are going to really limit the power this engine can make.. Your first priority should be to custom make some long tube 1-5/8" or 1-3/4" headers for your car.
None of your fooling around with different cams etc will make up for this. The bigger Magnum cams or any other real cam will not work good with crappy shorty headers.
The cam and headers must work together. Long tube is best. A decent well fabricated custom shorty race header can work well (the cam grind is different for4 these)
but do not expect big things from the bolt on stuff.
If that is your choice the XE274H-10 hyd cam is about as good as any.
The exhaust will limit the power.
  #42 (permalink)
Old 02-15-2013, 03:16 PM
Approximately how much power will i be losing by using Shorty headers as oppose to long tube?
I dint realize that the scavenging effect of long tube headers had such a large affect on engine HP.
Also i am currently intending to run the Comp cam 292H cam with 292/292, Lift .501/.501,. Not sure yet on if i want to switch to a solid lifter cam as this is mostly a street car.
  #43 (permalink)
Old 02-16-2013, 08:55 AM
vinniekq2's Avatar
long duration hydraulic flat tappet
those long duration cams give you a very lumpy sounding idle.
the sound rarely matches the performance
Is this a good set of heads? Zeder Engine 20 12-08-2004 04:17 PM
Is this set of heads any good? batman09 Engine 3 09-22-2004 10:19 AM
Good Set of heads? Camaro2Fast4u Engine 5 07-10-2003 08:34 AM
Where to buy good set of used cylinder heads.. chevyteen17 Engine 4 03-28-2003 05:01 AM
For the price of new heads would it not be better to refurbish a good set of old ones stonedchihuahua Engine 52 12-26-2002 12:38 PM
