Would a 4 speed manual out of a 78 trans-am work with a 85 monte carlo because i am dieing to convert it to manual and i know of this transmission for sale
What engines are they? If they are the same make sure you get all the linkage, tranny mounts, and maybe even the crossmember. Check the drive shaft length too! Good luck!
M.F. |
mine is a 305 and the one that the tranny is in is a 400. thanks
the engine is most likley the stock one so i guess ill have to do some more lokkin for tannys
John, what type transmission is the manual. If it is Borg Warner, Saginaw, or Muncie it should fit the Monte. You might have to change u joint or front yoke on driveshaft or even drive shaft. Get clutch disc that goes with tranny to have correct input spline. May have to move crossmember back etc but both are GM and should work with a little elbow grease. Opps forgot to ask if you have a chevy bellhousing for your engine? If so few or no problems. Pontiac housing won't fit.
[ September 02, 2002: Message edited by: twoteam ] [ September 02, 2002: Message edited by: twoteam ]</p> |
Thanks for the info! i just know that it is the stock tranny in the 78 trans am so ill try to find out what kind it is i dont now about the bellhousing but ill try to find that out
its a borg warner
