Would you spend another $400 on this rearend? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2004, 04:03 AM
I bought a Ford 9" rearend from this crook that was supposed to bolt right in, a 28 spline Detroit locker (which atcually was a mini spool)3:89 ratio,anyway heres the problem would you use the old 28 spline axles and buy some kind of posi unit,or call Moser and spend $400 and get 31 spline since i have to buy a posi. unit reguardless?How much stronger will 31 spline Moser axles over old 28 spline Ford i have now?I will be running about 450HP
Old 07-16-2004, 05:59 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Re: Would you spend another $400 on this rearend?
Go for the 31 spline axleshafts, and lose the spool for the best differential you can afford, a locker being the best for durability sake.
Choose what YOU feel is best for yourself.
