wow 8.8 better than i thought - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2009, 10:30 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
after doing a small amount of homework (not having much time he was selling it 50 bucks and had to get there before some else did) i bought an 8.8 out of a 93 explorer (31 spline 327 traclok) off of craigslist
thinking it would be a good tempoary axle until i could afford to build a 9"
now after doing a lot more home work i think this axle is going to stay for a long time
is anyone else using this rearend
Old 02-02-2009, 04:55 PM
SSedan64's Avatar
Many are using the 8.8" rear. It's basically a copy of a GM 12 Bolt. It's not identical but, close.
Old 02-02-2009, 05:39 PM
I don't understand?
yup, ive learned it is very close to 12 bolt in size and when it comes to axle size, the 28 spline is a little smaller, and 31 spline is a little bigger than the 12 bolts axles
i didnt realize it was that good when i bought it.
i just knew a lot of the jeep guys were using them
and of course the newer mustangs had them and they some can hand out some abuse
its a hair wider than what i wanted (59 1/2") because i read that i wanted 58"
but i can work with that
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Narrowing 8.8 jhenry Transmission - Rearend 3 08-17-2003 01:50 PM
8.8 rear questions mike bryan Transmission - Rearend 2 05-19-2003 03:38 AM
Ford 8.8 questions mike bryan Transmission - Rearend 2 05-17-2003 08:01 AM
8.8 ford and 9" Hack Job ??'s ChopTop Transmission - Rearend 6 01-28-2003 10:48 AM
