Is it woven cloth or random fiber mat? I don't have a concept of what 'wrinkled' means. If it is tightly creased wrinkles, this will severely weaken the strength of the cloth. After all it is just glass and dowsn't like being bent. If it is just mild waves, no problem. Regardless, the 'body' of this material is artificially applied by a resin soluble binder so the cloth should calm down when you soak it with the resin. Try a test with a small piece but I am pretty sure it won't cause you any problems once it is wet.
