Wrinkles when sewing curves on vinyl - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2012, 05:37 PM
Hi, can you help me figuring this out? I sew a curve and top stitch it and it creates wrinkles and or dimples. I trimmed all the salvage underneath but it didnt help.
Marine cushion
https://picasaweb.google.com/home?al...tos_from_posts
Old 03-14-2012, 06:43 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Sorry, none of your pictures are showing up. I can tell you right off the bat that cutting out the selvage (not salvage) won't do any good, in fact it will hurt rather than help. Until I see what you're talking about I can't help you.
Old 03-14-2012, 08:21 PM
Even happens with single top stitch
Here are the pics in photobucket
http://s1235.photobucket.com/albums/ff421/mortizx/
Old 03-15-2012, 08:12 AM
Wiki Edits: 22
It looks to me like you're stretching one piece of the vinyl as you're sewing. Are you trying to follow witness marks? Here is what it should look like. I make relief cuts on one side of curved seams to let the fabric overlap before top stitching.
Is one side plain and the other side has sew foam?
ID:	63981   Click image for larger version
ID:	63982   Click image for larger version
Old 03-15-2012, 09:25 AM
WOW... That help alot thank you. Now im coming up with one side shorter than the other. Is it possible for you to send me a video on how you did it? I would really appreciate it.
Old 03-15-2012, 08:40 PM
Wiki Edits: 22
Vinyl creeps really bad when you sew it together, especially longer pieces like you are working with. I make the pieces even longer and then cut the whole thing down to the right size when the pieces are all sewn together.
Old 03-15-2012, 08:53 PM
nine4gmc's Avatar
I often catch myself pulling one side(particularly the top) when doing curves. It looks just like the cushions your post, mortizx. When mine does that, and one side comes up a bit short after redoing it, I note the shortage and try to "stretch" the short side just a bit in the long straights to compensate for that shortage. if its a big difference, the pattern may be off.
*edited OFF TOPIC QUESTION, I meant to ask Dan, what brand/pattern vinyl is that you used in the example above?
Old 03-15-2012, 09:25 PM
Wiki Edits: 22
You can sew two long pieces of vinyl together 20 times, and it will come out different all 20 times. There's no way to predict what will happen. Stretching one side or the other is what caused his original problem.
The vinyl was a scrap from another job, and I don't remember what it is. It is nice looking, isn't it? I'll see if I can figure out where I used it tomorrow. I think it was used in a 46 Ford I did about 1 1/2 years ago.
Old 03-15-2012, 09:52 PM
nine4gmc's Avatar
Dan, it is really nice looking, I would love to cover my old set of Chromcraft chairs in that stuff. Most of the supplies I get are from Woolley Bros cause of convenience, they are right across town but their inventory is not real exotic to say the least.
Back on topic, great point, stretching it is what caused the problems to begin with so mortizx, don't listed to me or you will end up chasing your tail!
Old 03-16-2012, 07:34 AM
Wiki Edits: 22
I actually figured out what that vinyl is. It is part of the Allante collection from Morbern called Carrara Tan #CR-509. Here's a link to it: CLICK HERE It's available from Miami Corp: MIAMI
Here it is on a '46 Ford door panel.
Old 03-16-2012, 03:32 PM
nine4gmc's Avatar
Dan, Thanks again for taking time to help all of us, you do not know how much it means.
Old 03-16-2012, 09:05 PM
Wiki Edits: 22
I can't always have the right answer, 'cuz I'm not always sure how to answer the question. I hope I get the answer right 75% of the time.
Old 03-17-2012, 07:15 AM
I am having this same trouble too. I am making door panels with a 4" carpet on the bottom, a 12" pleat in the middle and a piece with no pleat on the top of the door panel. between the top and the middle pleat it doesnt go straight across the panel -it curves about 45* to the top of the panel. There is a piece of welt cording between the pleat and the flat piece.
What does "witness marks" mean?
Do I trim the foam away where the pleat and the flat panel meet?
So far I have the welting sewn to the flat panel and it looks great. I can just see that it is going to be a problem to sew the pleated piece to it.
Any advice?
Old 03-17-2012, 08:58 AM
Wiki Edits: 22
Witness marks are marks or notches that allow you to line up two pieces of fabric that you're sewing together.
I would sew the welt to the pleated area first, and sew the flat piece to that.
How are you padding the flat area? What kind of material is the panel made out of?
Old 03-17-2012, 12:02 PM
I am padding the vinyl with 1/4" "scrim" - i dont know what it is officially called.the local supply ship had it. The pleats and the flat is from the same vinyl
Sewing heat pleated vinyl hkestes Interior 5 06-09-2011 09:40 AM
Sewing Around Curves? Coodeville Interior 0 12-04-2010 11:01 AM
seat wrinkles qhr1 Interior 3 10-14-2010 11:15 AM
wrinkles in vinyl?? charliec Interior 2 05-04-2004 06:37 PM
