Wrist pin ...cannot decide!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2009, 08:46 AM
rockher_man's Avatar
Man...this is drivin' me nutZ...I got this nailed down to 2 choises!
I WON a set of Probe Industries forged pistons of MY CHOICE!
I'm lookin' at these ...and here they are...
http://www.probeindustries.com/ProductDetails.asp?ProductCode=10666&Show=TechSpec s
http://www.probeindustries.com/ProductDetails.asp?ProductCode=12347&Show=TechSpec s
About the only differences in the two are the wrist pin diameter ...which in turn...affects the ring lands!
Ring are 1/16---1/16---3mm and compression ratio is 10.37 with 58cc chambers.
Kool...I know...where my little brain in stuck between gears is...I jammed up
tryin' to figure out iF it is worth gettin' all worked about the difference in the pin sizes?
OK...please...no jokes about...well...never mind...
One uses a 0.912 pin & the other uses a 0.927 pin. Seems stupid...right?
Not when you...X8...figure reciprcating weights at 5500 rpms +...etc...
A gram here-n-there can add up for a "budget" build stroker project SBF...
This has been keepin' me awake at night for a while now...any ideas?...
-ThankZ...
Old 12-01-2009, 08:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Well, IIRC 0.912" is OEM SBF, 0.927 is SBC. Depending on the rods you choose to run, their could be a reason to use the bigger pins. Otherwise run the Ford spec pins, IMHO.
EDIT- Your links don't work, but I ran the following down from Probe's site:
Ford 331/347 Flat Top -4.0cc - SRS Piston Set
Part Number: 10666
1.175" Compression Height
3.250/3.400" Stroke
5.400/5.315" Rod Length
0.912" Pin OD
1/16 in. 1/16 in. 3.0 mm Rings
Available Bore Sizes: 4.000", 4.030", 4.040"
Part Number: 12347
3.250/3.400" Stroke
0.927" Pin OD
Because neither set of pistons are designed for SBC length rods (5.7") is all the more reason to stay w/the SBF pin size. It's lighter, anyway.
Old 12-01-2009, 09:28 AM
Ooopppps...
Yea...I left "some" info out...sorry...I was planning on goin' sort of conservative...sort of likin' this setup...
http://www.probeindustries.com/Produ...Show=TechSpecs
...cause I met a dude that has been runnin' a similar Eagle stroker kit
for 7 years and it still runs like a scalled dog..in a 3800lb. car daily driver
that see's the 1320 3-4 time every month!
NO offence meant to any K9's what-so-ever...
Old 12-01-2009, 09:51 AM
Banned
You're way over analyzing this for a street build. Run the pin that fits your rods. There a lot of much more important things to worry about.
Old 12-02-2009, 08:33 AM
I agree...
I came to that realization last nite...man...was I overthinkin' this thing or what?!
I DO want to say ThankZZ anyway...
I am goin' with new rods...Probe lightweight I-beam 5.400" ....
I figure...if I'm goin' this far...might as well make ol' Henry proud and stick with a Ford in a Ford...ya know...
Thanks again...
Wrist pin walking? zildjian4life218 Engine 12 04-22-2009 05:52 PM
"Basics of Basics" Rebuilding hinges. MARTINSR Body - Exterior 0 09-30-2007 11:16 AM
wrist pin troubleshooting sbc 350 1984stepside Engine 3 07-06-2007 05:30 PM
wrist pin remover nix Garage - Tools 2 01-26-2006 02:02 AM
will any wrist pin fit any piston? jesse01 Engine 5 03-24-2005 03:44 PM
