wrist pin remover - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2006, 07:38 PM
nix nix is offline
wrist pin remover
what to use and how
im lost
nick
Old 01-23-2006, 08:08 PM
BOBCRMAN@aol.com's Avatar
For non floating pins?
A fixture is used in a press. The fixture holds the piston/rod assembly in place and an arbor is inserted into the pin. Arbor is then pushed thru under pressure, forcing the pin thru the rod end and piston pin bore.
To assemble the rod "eye" is heated, the pin is quickly inserted and captured as the rod cools.
Old 01-26-2006, 03:02 AM
When I was a kid my dad used a piece of all thread some big nuts, washers, a pipe nipple and piece of steel that was just smaller than the wrist pin to remove a piston on his old Corvair van. I can't remember heating anything of course back then all we had was a propane torch.
will any wrist pin fit any piston? jesse01 Engine 5 03-24-2005 04:44 PM
421 small block chevys hardup12001 Engine 1 12-25-2004 07:46 PM
Weld Pin Holes and Body Filler Ron M Body - Exterior 3 08-25-2004 03:15 PM
changing a 4 pin distribture to a 7 pin geno Engine 5 01-19-2004 05:31 PM
anyone know why wrist pin offset is important? 57Waygone Electrical 3 11-27-2003 11:55 AM
