Is this wrong advice? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 10:01 PM
Came across this hot rod article today.
http://www.hotrod.com/howto/53938/
They say apply a coat of etch primer and then apply filler over that. It was my understanding that filler was not to be used over etch primer. Interesting though is I took a quick look at the P=sheet for the etch primer in question and it says not to use epoxy primer over it. When I was first learning all this stuff, the icar procedure was to use etch primer over bare metal, and then use epoxy over that. Has something changed?
Old 07-31-2005, 10:32 PM
Yeah, filler should never be applied over etch primer NEVER.
That DPX 171 etch is not friendly with epoxy either, but on the other hand Dx1791 is. At my last PPG cert class they wanted Dx1791 under DPLF epoxy and only dx1791, as they said it adds to its corrosion resistance. DPX171 reacts with the epoxy causing for a failure
The thing with Icar is that they are general guidelines, not product or specific guidelines. If you want to know how a product is to be used read the product P-pages or tech sheet not the Icar guidelines...Eric
Old 07-31-2005, 11:01 PM
Thats what I figured. I can just imagine how many readers they have that don't know better and follow their advise. I hardly ever use etch primer anyways. And yes I always read the p-sheets. Its easy to forget somethings even if you have used the product alot, and sometimes the recommendations change or are updated. Plus it is hard to keep up on every single product, and stuff getting phazed out and replaced means you need to learn the new products.
HELP!!! Differential Repair from Hell! If it can go wrong, it has! BCinDC Transmission - Rearend 2 03-13-2005 10:13 AM
Melted piston, pistons in wrong holes!!! MEAN_SBC Engine 39 07-31-2004 05:20 PM
"Taste" or just plain WRONG MARTINSR Hotrodders' Lounge 7 07-25-2004 08:05 AM
Newby - Need some advice Wyatt55 Engine 9 05-19-2004 10:35 PM
M II Frontend, Whats wrong here Bluepen Suspension - Brakes - Steering 7 02-28-2004 06:48 AM
