Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wrong guage reading
Old 04-07-2007, 03:38 PM
goshawks00 goshawks00 is offline
NEXT, get a Linear taper potentiometer, (like an old radio volume control ) (rat shak ,$3,00) Say, your system is 0 to 60 Ohms , get your linear taper (pot) within a range of 0 to 100 ohms at 5 watts..
Doc after driving 30 miles to the nearest Radio Shack
I asked for said potentimeter, only to br told they don't carry sucah a creature ... the best they had was a 1k @.25 watts. I told sure you do Doc said so, well that made them look it up in their catalog athen they told me they don't carry anything even close. Any ideas where to find a 0-100 ohm @5watt pot?
I did find one close from an electronic store on the internet:
Wire wound element - Continuous rotation -Gold plated plug on terminals - Brass bushing - Stainless steel shaft
Standard resistance range : 50,100, 200, 500,1K, 2K, 5K, 10K
Electrical angle : 350 degrees
Power rating 0.5 watt
Life expectancy : 1,000,000 turns
Options: Ball bearings, center tap, multiple gangs, sealed body , o ring shaft seal, servo mount,
continuous rotation, flattened , lengthened or rear shafts dual concentric shafts, for wirewound version see SP22B
but they start @ $30.00
