wrong intake manifold gaskets? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2010, 03:26 PM
hemi joe's Avatar
loves ex cop cars
hey everyone,after pulling my intake manifold on my 87 caprice 5.7L/350,i found the intake gaskets are for a tbi.my car is carbureted could this cause overheating since back ports are blocked off.the correct gaskets are open for carbed motor.plus i think i was sold a reverse flow water pump which caused my overheating problem.any thoughts on this issue?
Old 08-16-2010, 03:35 PM
SSedan64's Avatar
The reverse flow Pump will definitely cause a problem if your car's Pump doesn't run a Serp belt. I don't think the blocked ports will as some intakes don't have flow thru the Intake at the rear. Did the rear of your Manifold have open ports or just the gasket had open holes? Many are that way so they fit either side.
Old 08-16-2010, 03:51 PM
hemi joe's Avatar
loves ex cop cars
the reason i ask is all the gskets for my motor have open rear ports,even my edelbrock performer has open rear ports.i agree with the water pump i have a new one ordered.
Old 08-16-2010, 07:43 PM
hemi joe's Avatar
loves ex cop cars
i quess no one knows what i'am talking about?
Old 08-16-2010, 07:50 PM
ericnova72's Avatar
More for Less Racer
The SBC intake gaskets have water holes in both ends so that they are interchangeable and can be used on either side of the engine. There are no rear water ports in stock OEM intakes, it is only aftermarket performance intakes that have water ports in the rear, for the guys who want to modify their engines for four corner water return.
It would have nothing to do with your overheating problem.
Old 08-16-2010, 08:23 PM
hemi joe's Avatar
loves ex cop cars
not true,the gasket for my car has the rear ports open.gaskets for tbi are closed.look it up,i have a 5.7L/350 CARBURETED MOTOR.TBI IS DIFFERENT GASKET.LOOK IT UP!!!the 87 roller motor is different,believe me,you guys are being stuburn.get off your high horse and look into this!!!
Old 08-16-2010, 09:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It does not make any difference to the way the engine cooling system works, if the gasket is open or not on the rear ports- the rear ports dead end at the intake manifold- there is no water passage from the head into the intake. The water stops at the intake, whether it stops at an open gasket that butts into the intake or if the water port in the head is covered by a gasket, the intake has NO rear water passage.
The "traditional" intake gaskets have holes front and rear- this is only so one gasket needed- one gasket will fit both sides of the engine.
Old 08-16-2010, 09:28 PM
hemi joe's Avatar
loves ex cop cars
ok than what is that rear passage for.i don't understand,i need to be educated.
Old 08-16-2010, 09:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The rear passage in the head is there so it can be used on either side of the engine- both sides use the exact same casting.
There is no passage in the rear of the intake, as I mentioned before. The front passage is what is used. The gasket is similar to the heads- one gasket (like one head) will fit EITHER side of the engine.
Old 08-17-2010, 04:05 AM
physcult's Avatar
On my 350, a previous owner had run a hose from the back of the manifold to the opposite cylinder head - I wondered what that was about. I guess it was someone trying to put a waterway where there isnt one, for what purpose Im unsure.
My Weiand inlet manifold has no waterways in the rear of it- so I presume it isnt important to running temperature.
Old 08-17-2010, 09:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some intakes come plumbed (or are modified) so the rear head passages can be tapped into, this is so external coolant lines can be used.
This isn't necessary on most street-bound engines.
Old 01-09-2011, 11:39 AM
i pulled the gaskets from my 89 caprice classic and only one of the ports on the back of the old gaskets were closed and my new gaskets both of the back ports are closed will this still work or do i have to go buy new gaskets again
i have a 89 caprice v8 305 fuel injected
Old 01-09-2011, 12:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The gaskets you now have are correct. I show the correct gasket set (<$20) to be:
Fel-Pro - Intake Manifold Gasket Set Part Number: MS93317
Old 01-10-2011, 10:44 AM
Ok thats the exact set that i have the reason im asking is because the set out of my car has one of the back ports open and one closed but ill put the new set in n see wat happens thanks
Old 01-10-2011, 10:47 AM
If your heater circuit comes off the back of the head/intake then you need a gasket set that opens the rear coolant returns.
If your heater circuit comes off the front of the intake where the return collector is, then a gasket that blocks the rear returns would not be a problem.
Bogie
GM series II 3800 top end diagram fast68 Engine 15 04-24-2009 09:40 PM
Leak on top of SBC 350 intake manifold 75gmck25 Engine 9 01-23-2009 09:11 AM
Mr Gasket intake manifold gaskets 68 Pickup Engine 1 03-20-2008 09:02 PM
Intake manifold temperature and gaskets club327 Engine 3 07-19-2005 12:22 AM
SBC Intake manifold - needs crossovers?? Limey Simon Engine 7 01-27-2003 11:56 PM
