He is correct. The oil ring support rails are missing..
Because the pin intrudes into the ring groove. An oil support ring is installed then the three piece oil ring. This leaves two rings on bottom. Then expander, then single ring on top. |
If you want to run the 6" long rod there is not too much you can do differently. Oher than run a two ring piston.
Performance wise, on a street engine, there is little to no difference. Between a 5.7 and a 6" rod. The rails, properly installed, are no problem. A better alternative than the old method of "pinning" the lower oil rail. This method led to too much oil rail deflection at the pin hole. Due to no rail support. The rail support ring is used on many of the stroker BBC's that I build. No problems. |
| stroke to rod ratio | jacobm99 | Engine | 17 | 09-16-2010 10:06 AM |
| Synthetic oil and engine break in. | DoubleVision | Engine | 0 | 07-27-2009 06:09 PM |
| Cam Help | shsouthard | Engine | 18 | 03-29-2009 09:33 PM |
| OOPS! Mixed up my SBC piston rings | enduro54 | Engine | 5 | 01-18-2009 12:18 PM |
| SBC low oil press but no rocker arm noise? | myclone614 | Engine | 14 | 01-23-2006 04:16 PM |
