Is it wrong to put a Fiero part in a Vette? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2009, 09:16 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
Is it wrong to put a Fiero part in a Vette? My alt went out and I had 2 Fiero alts just sitting here, some of the case had to be smoothed down but its on and working fine. It should hold up better than the one that came off the car, its an Delco.
I will put the bad one in my core pile for later use if I have to replace the one I just installed. I noticed that the Fiero alt is a little bit smaller, its hard to tell but if you look close it looks like its smaller. It could just be due to the bad one being an after market alt.
Anyway, got the job done and the car is back on the road without spending a dime.
Old 01-03-2009, 09:20 AM
5_speed's Avatar
1988 Dodge Dakota 318 Magnum
Thats what hot rodding is all about.
Old 01-03-2009, 09:45 AM
poncho62's Avatar
Wiki Edits: 5
A Corvette alternator is just a Chevy (GM) part, as is a Fiero...........Just the Corvette price is likely different.
Old 01-03-2009, 09:53 AM
Shhh the corvette forum will hear you.
I did look up the parts numbers and made sure it would work. The pulley is a little larger than the pulley off the old one but the old one was destroyed so I had no choice. Couldn't see paying for a new or rebuilt part when I had something I could make work.
Old 01-03-2009, 11:44 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Are they both rated for the same amperage? That's what I would be concerned about.
If the Corvette has more electric/electronic components it's possible that it could have had a higher output alternator.
Old 01-03-2009, 11:48 AM
Good question, the one that went bad didn't have any labels on it so I cant look it up. I will have to look both cars up and see. Its charging like it should. Find out in a couple of days if it wont keep the battery charged.
Old 01-03-2009, 12:02 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
As long as it aint broke don't fix it..Just being facetitous or one of those fancy kind of words.. Seriously as long as it is working why bother..Unless of course this is one fo the Anal Special variety of Corvette...
Sam
al
Old 01-03-2009, 12:30 PM
Looks like its about 10 amps less than the one that is listed for my Vette. I took it for a drive and its working fine so I will leave it.
Eventually I will replace it, the engine is the best thing about this car. I just wanted it fixed so I didn't spend a lot of time cleaning it. Its probably the worse looking thing in the engine bay but it works and I can live with it until the time comes to replace it.
Old 01-04-2009, 11:48 AM
72 grabber 51F-1 65 chevystang
I don't see a problem with it. I would use it til it breaks. At my house we never buy alternaters or starters, we have piles of both
Old 04-10-2009, 07:53 AM
LOL, if it works, and you saved yourself a couple bucks, give yourself a pat on the back. Lisa's (my wife) Fiero, has corvette headers, corvette composite water pump, corvette front brakes. (11 inch IIRC) if it fits more power to ya. I Once and only Once went into a Caddy dealership with my Caddy powered Fiero. I got comments like Champagne in a Beer Glass, and a few others I won't repeat. Suffice it to say I never went back there. Went to a regular Chevy dealer and they got me all the Caddy parts I needed and were very pleased to see a Caddy V8 stuffed in the back of my Fiero.
Old 04-10-2009, 06:52 PM
Hey Capt Fiero welcome to the forum.
I have a 74 corvette motor in my Fiero.
Old 04-10-2009, 07:22 PM
IT'S TOO LATE... i'm from the corvette forum and i already read it. .
Old 04-10-2009, 07:33 PM
Oh no don't turn me in
The alternator has been working great, even keeps up with my amps and speakers. Other than the small part I had to sand down by the mounting bracket it was a bolt on part.
Old 04-10-2009, 07:38 PM
don't worry, your secret is safe with me. i'm not one of the NCRS nut jobs....
Old 04-10-2009, 08:38 PM
302 Z28's Avatar
The Vette minions will seek you out as you sleep and infect you with Vega, Pinto, and AMC Pacer DNA.
Vince
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 12:21 PM
home anodizing??? hmmm General Rodding Tech 13 06-28-2004 04:48 AM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 07:27 PM
