WTB: Narrow Slot Mags - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2006, 11:38 AM
I am looking for a pair of narrow slot mag style rims for the front of my 55 1st series chevy pickup. I have some 15X7"-ish wheels, but the tires rub on the fenders when turning (the pickup has been lowered, pacer ifs, etc.). I am thinking I'll need around 5" width. 14" or 15" diameter would be fine. 5 on 4.5 bolt pattern.
Any ideas where I can find a pair without spending a fortune? Ebay hasn't been much help.
Old 12-13-2006, 11:55 AM
Frisco's Avatar
Glad To Be Here
Narrow slot mags are hard to find and I've not seen any "cheap" ones. Most current manufacturers no longer make the narrow rims. The few that do are high priced.
I also am looking for a set and check eBay daily. Do a search for Ansen, Fenton and slotted mags there.
If you have disc brakes on the front you will need to run 15" rims to clear the calipers.
You might also be able to run a wider rim with more backspacing than what your current rims have. This will give more tire to fender clearance.
Old 12-14-2006, 12:27 PM
I was afraid that would be the answer. I will have to look into the wide rim with more backspacing. Thanks
Old 12-18-2006, 07:27 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
That or change wheels all the way around. I needed a deep offset 7" wheel to run on my Rambler w/Jag axle -- that or narrow the axle. I found that you can't get a 5" offset 7" wheel from many people, even the so called custom wheel makers couldn't do it! I did find that you can get Weld Drag Lites in darn near any width and backspacing though. They coul go 5.5" deep on a 7" wheel, and might could have gone 6" (don't recall now...). I know they had lots of narrow wheels in just about any backset in .5" increments.
Old 12-18-2006, 08:29 AM
powerrodsmike's Avatar
Wiki Edits: 161
Have you cosidered narrowing your rims? There are several companies in the us that will do it. I wound up getting it done myself using local companies. The cost was about 300.00 for the pair, but we got the width we needed, and didn't have to send it out..My customer was very pleased with the result and the wheels work perfectly.
Here is the thread with that story
Narrowing aluminum wheels update
If any of that interests you, I can get the names of the companies that will do it for you.
Later, mikey
BE different....ACT normal.
Old 12-20-2006, 07:42 AM
Mustangsaly's Avatar
you looking for something like whats on the front of this ? I will ask my buddie as I know he went nuts a couple yrs ago buying 15" ansen & fenton and ET alum slots. I know he bought like 5 or 6 sets of new nos ansen & fenton and ET center caps. not sure what he has or what he will sell. plus he knows what they will bring. hes in the office of a salvage yard and will retire on the parts he has rat holed. hes a BBC nut, but has a bunch of SBC & BBC complete motors/blocks and steel cranks ect. and mopar and ford motors & parts plus ford 9" rears. plus all the late model desirable motors & parts. he has a 60x100 steel building full. hes 44yrs old.
Mustangsaly
Old 12-20-2006, 10:29 PM
Farna - Yeah, I have been thinking about changing all the way around. It won't be leaving the garage until late spring anyway, so I have some time. If I don't find anything by then, 4 new rims it'll be!
Mike - Sounds like it could get expensive when you figure in $300ish like you said, plus shipping both ways. I'll keep it in mind though.
Mustangsaly - That's it! That's what I'm looking for. Let me know if you have a connection for some.
Dave
Old 12-20-2006, 10:34 PM
Frisco's Avatar
Glad To Be Here
Dave
Me too except those are probably 4.75 BC (Chevy).
Got any with 4.5 BC (Ford)?
Old 12-20-2006, 10:41 PM
Hey now Frisco, I am looking for 4.5 bolt pattern too. I got first dibs
Old 12-20-2006, 10:45 PM
Frisco's Avatar
Glad To Be Here
I got your back!
Mustangsaly implied that they knew of someone that had many put away. We'll see what comes up.
Old 12-26-2006, 02:42 PM
hes gone till jan 15th
Mustangsaly
Old 12-29-2006, 05:56 PM
ok guys I talked to my buddie and he said
No extra narrow ones for sale. might have a set of 15X10 AND 15X11 BIG$$$$$ right around the area of $200 TO $250 PER PAIR... 1 set of ansens that need restored and a set of fentons that need restored, but be awhile be for selling any.
I know he has prob 10 sets of 4 that are 5" or 6" fronts & 8" and 10" rears and several sets of the real narrow ones, hes holding out.
Mustangsaly
Old 01-14-2007, 01:50 PM
here are some American Racing Alum Slot wheels, 5x5.5 bolt pattern, in colorado springs colorado.
http://cosprings.craigslist.org/pts/261704907.html
Mustangsaly
ID:	17706   Click image for larger version
ID:	17707   Click image for larger version
Mini tub, narrow rear first or buy wheels first? CHASINGJR Transmission - Rearend 3 09-20-2006 11:21 AM
Hotrod mags 78 monte Hotrodders' Lounge 34 07-11-2003 01:09 PM
Good Rod Mags spookabilly Hotrodders' Lounge 9 10-21-2002 07:35 AM
