"X" Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2008, 02:29 AM
"X" Heads
I'm pocket porting A set of 339 heads. They've been through a machine shop & one of them didn't make it through the crack check.
One of the heads is 339
The other head is a 339X
I noticed when mildly porting the intake around the guide boss on the common wall that the "X" head had more space between the guide boss & the port wall.
So what's the deal with X heads? Do they make more HP? If they do How much over the regular non-x issue heads?
Old 08-25-2008, 06:18 AM
SSedan64's Avatar
On some heads the "X" means 10cc larger intake runners. I read this part on the forum = Others "X" ment larger combustion chamber & larger intake runners.
Old 08-25-2008, 11:06 AM
Looks like the larger intake runners apply in this instance.
Haven't looked real close @ the combustion chambers yet.
Only did port work on the intake bowls last night.
Almost done on all 8
Next, I'll need to read up a little on the exhaust before heading in with the carbide.
I sure don't want to remove anything that wont matter.
Old 08-25-2008, 08:38 PM
I always heard that the X heads (powerpack era) were eXperimental early production heads before the final design was settled on.
Shane
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 10:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
