Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Xe268 wiped lobes
Old 02-18-2012, 10:41 PM
1969chevyss's Avatar
1969chevyss 1969chevyss is offline
Xe268 wiped lobes
Hey guys I have a 355 short block with a xe268h cam stuffed in her. I have a set of vortec heads that I will get new springs to accomodate the extra lift. My question however is this, are there any other good lifters besides the ones that comp cam recommend(812-16) that will help me prevent the chances of my cam going flat. I have been doing a lot of reading and this seems to be a reaccuring problem with this grind. My next question is for my vortec heads, what sprints can I use that will drop right in without any machine work. I read that z28 springs from northern for 525 lift will work, just would like to get you guys opinion on the matter. Thanks in advance.
