Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Xe268 wiped lobes
Old 02-19-2012, 02:49 PM
stich626's Avatar
stich626 stich626 is offline
Last journal entry: The TwoTonShu #10
Originally Posted by Studebaker
Compcams flat tappet hydraulic failure rate is unacceptable. They know there is a problem and their answer is to keep their fingers crossed and hope for the best. I really like the Compcams grinds but I would not use anything from Comp again. When a cam fails, this requires a complete teardown. Will Comp stand behind the product. Hit and miss. If they know the XE series has high fail rates, why woudn't they nitride all cams in this series. It's simple, it's about customer service and doing the right thing, not excuses. How many out there are using Comp xe series cams? Did your cam fail?
comp,cams failures are caused by lack of correct oil, and the fact that they have a problem with a line of fakes, being sold as comps.
We've never had a camp.s go flat, but we use the correct oil, liter springs for break in, and buy directly from comp. bypassing the chance of being sold a fake(counterfit) . that a major speed shop is halking.
