Xe268 wiped lobes - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-19-2012, 11:07 PM
Well I dont think the desktop dyno can be too terribly far off. Its only 50ft lb over what my engine is rated at stock. The engine IS stock but will be getting headers and exhaust and a K&N filter. Who knows what else. Also I might have to advance the cam a little to push the torque curve down - I am planning on doing some towing with this truck. About 6,000 worth.
Still yet, even if i only gain 30 ft lb, that puts me equal to a chevy 350 of the same year. 350s tow OK.
Big thing tho is still the fear of wiping out a cam. I know the engines are a good bit different between the SBC and SBF.
  #32 (permalink)
Old 02-19-2012, 11:51 PM
F-BIRD'88's Avatar
Yada Yada Yada
Advancing a cam will not "push the torque curve down"
Shorter duration, will. VERRY easy to over cam a 302. a larger than stock cam requires a higher towing rpm. ( gears )
50FT/lbs difference betweent eh real and virtual simulation is huge.
You best reconsider your inputs for the engine modeling choices.
This graph shows the basic effect on a engines torque curve when the cam is advanced or retarded. A duration change basicaly moves the whole torque curve up or down the rpm range.
A torque out put GAIN increase requires a increase in total engine AIR flow.
improved volumetric effieientcy or a reduction in friction or a increase in compression or engine CID.
  #33 (permalink)
Old 02-20-2012, 11:31 AM
1969chevyss's Avatar
I called Isky this morning and they recommended the 264 Mega. This camed will give me more low end torque with a noticeble lope at idle but nothing to extreme. He said he have heard from people that the 264 Mega out perfomed some xe268h. The Mega 268 would fit my combo as well if I was planning on changing the stock gears and converter. I'm glad I brought this issue up now and not later causing me to tear the motor down for a flat cam. I know it is still up to me to break in the cam right and use the right oil additives.
  #34 (permalink)
Old 02-20-2012, 01:51 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Here's a checklist to help you out.....
http://www.crankshaftcoalition.com/w...ips_and_tricks
  #35 (permalink)
Old 02-20-2012, 04:52 PM
6426yy's Avatar
This is the cam I have in my pickup right now with a 355, th350 and 3.73 posi 12 bolt, summit hyper flat tops, steel shim head gasket and fresh 993 heads with small valves, Holley streetmaster intake with a divider installed and a 600 Holley it runs very well it actually surprised me and my buddies, I'm fixing to install vortec heads this spring after I clean them up and cut the guides down for positive seals, I run the cheap lifters all the time from competition products, or summit using diesel oil and Zddp and never had a problem. I have a comp 4x4 extreme in my 454 and it hasn't went flat broke it in with the outer springs only. I think cam failures are mostly installed wrong and the people don't want to admit they don't know what there doing.
http://www.competitionproducts.com/E...ctinfo/E1065P/
It's close to the comp 268H and has a very nice idle.
  #36 (permalink)
Old 02-21-2012, 05:37 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
x2
easier to blame the maker of the cams
  #37 (permalink)
Old 02-21-2012, 02:06 PM
Senior Curmudgeon
Wiki Edits: 326
I agree. Most people cannot admit it when they're wrong.
  #38 (permalink)
Old 02-21-2012, 04:39 PM
I bailed on Comp years ago.
If you're building a SBC, they probably make fine street cams.
If you want your junk to run like its supposed to, then look elsewhere.
For catalog cams, I only use Isky.
For race engines, I only use custom grinds.
  #39 (permalink)
Old 02-22-2012, 06:18 PM
lust4speed's Avatar
Well, you can say what you want about failures being caused by incorrect installation, but how do you justify the professional engine builders that went from no failures to several failures overnight? Then just about as quickly as the failures started, they have went away. There's still old stock from a couple of years ago being sold that should have been trashed, so we are still seeing a few failures with everything done right.
I don't believe that the cam blanks were the problem, but the white box lifters being sold during that time period. A crap lifter will take out even a good cam quickly. I may be wrong, but anyone heard of an installation with a set of Rhoads lifters going bad during that time period? Same cams, but different lifters didn't seem to have any problems.
Many years ago I ran a 268H cam in my (Pontiac) 455. Really great mid-range, but power flattened out about 4,500 RPM. Cam specs seemed like the power curve should have went much higher before running out of steam. Installed a Crower cam with close to the same specs and the power curve went 1,000 RPM higher before leveling off.
  #40 (permalink)
Old 02-22-2012, 06:59 PM
I'm going to take all the factors into consideration but I've already ordered the isky mega 264 with lifters. The xe268 probably would have been good for me with my mild build but why take chances especially at this stage in the build.
Cam lobes grinding down!?!? chevycarlo91 Engine 11 08-05-2009 06:01 PM
Wiped out a cam lobe :( 66GMC Engine 25 04-28-2008 05:49 PM
what lenght pushrods? wiped out cam? 78 ford 302 Warrant Engine 2 03-19-2007 11:26 AM
Article on Oil, Wiped Lobes HawkZ28 Engine 8 06-08-2006 10:33 AM
Questions for wiped lobe victims & engine gurus JPhil Engine 17 09-22-2005 07:01 PM
