Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - XE274 or 292H???
Old 10-18-2012, 02:53 AM
cdminter59 cdminter59 is offline
XE274 or 292H
Originally Posted by stackitup_91 View Post
Which cam would be better in this combo i already have the 292H comp Cam but i have about a month to decide if i need to keep this cam or go with the COMP CAM XE274.. motor is not in the Car yet still in the building stage.
I Have a 350 bored .40 over
Comp cam 292H, (501/501) Lift
1.5 ratio Roller tip Rocker Arms
VORTEC HEADS 64cc(with the Reccomended Beehive Valve Spings)
Edelbrock RPM airgap Intake
Flat top Pistons
Eagle Connecting Rods (Standard Length 5.7)
650 Edelbrock Carb
373 Rearend Gears
and hooker headers 1 5/8..
Thank you and responces are appriciated
What kind of car are you installing this motor in. Weight makes a difference. The heavier the car the more torque is needed instead of hp. How much vacuum do you need to operate power brakes, etc? Check out these graphs and look at the vacuum readings too. The larger the camshafts also need bigger carburetors and rear gears.
