Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - XE274 or 292H???
Old 10-18-2012, 06:52 AM
stackitup_91 stackitup_91 is offline
Originally Posted by cdminter59 View Post
What kind of car are you installing this motor in. Weight makes a difference. The heavier the car the more torque is needed instead of hp. How much vacuum do you need to operate power brakes, etc? Check out these graphs and look at the vacuum readings too. The larger the camshafts also need bigger carburetors and rear gears.
The motor will be going in a 84 camaro...
