Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - XE274 or 292H???
Old 10-18-2012, 06:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by stackitup_91 View Post
how much HP would you Estimate The Build Would Be with The XE274 Comp cam??
COMP CamsŪ - Xtreme Energy 274 Hydraulic Flat Tappet Camshaft, Part # 12-246-3 Dyno Sheet shows the HP (370 @ 5900 rpm) and torque (410 ft/lbs @ 3900 rpm) that cam makes using Dart SR heads and a vacuum secondary Holley 750. What's interesting is the power at 5100 rpm all the way to the peak at 5900 rpm is nearly the same.
Comp dyno graphs shows dyno results for the other XE series cams.
If you were to use the 292H, be sure you have enough compression or else it will be a dog.
