XE274 or 292H???
Which cam would be better in this combo i already have the 292H comp Cam but i have about a month to decide if i need to keep this cam or go with the COMP CAM XE274.. motor is not in the Car yet still in the building stage.
I Have a 350 bored .40 over Comp cam 292H, (501/501) Lift 1.5 ratio Roller tip Rocker Arms VORTEC HEADS 64cc(with the Reccomended Beehive Valve Spings) Edelbrock RPM airgap Intake Flat top Pistons Eagle Connecting Rods (Standard Length 5.7) 650 Edelbrock Carb 373 Rearend Gears and hooker headers 1 5/8.. Thank you and responces are appriciated |
The XE 274 if one of those two have to be picked. More low end power and more power under the curve using the parts you outlined, and will be much better on the street. The longer duration of the 292 will want more rear gear and converter stall.
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
stackitup_91 (10-17-2012) | ||
how much HP would you Estimate The Build Would Be with The XE274 Comp cam??
XE274 or 292H
the bigger carb I call fowl on.. a 355 cid will need the same air flow.. no matter what cam you slide in it.. it doesn't become a 455 just because you stuffed a big cam in it.. the bigger carb also hurts the low end torque that causes the need for bigger gears 3.90/4.10/4.56 so please explain.. |
Comp dyno graphs shows dyno results for the other XE series cams. If you were to use the 292H, be sure you have enough compression or else it will be a dog. Last edited by cobalt327; 10-18-2012 at 06:27 AM. |
| Tags |
| 292h, sbc, vortec heads, xe274 |
| Vortec Heads with 292h Comp Cam | stackitup_91 | Engine | 29 | 10-19-2012 02:43 PM |
| 292h cam gas? | 1967chevelle454 | Engine | 11 | 04-03-2008 05:27 AM |
| Comp XE274 | MI2600 | Engine | 15 | 06-28-2005 06:52 PM |
| Xe274 | MI2600 | Engine | 8 | 06-25-2004 08:42 AM |
| xe274 cam | 66truck4spd | Engine | 2 | 11-18-2003 07:42 PM |
