Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400
Old 02-28-2006, 07:07 PM
Pr0blumz Pr0blumz is offline
I was looking at "How to Build Big Inch Small Blocks" and they built a 406 sbc with vortec heads and a lunati cam. The specs were 9.5 comp. ratio, air gap rpm intake, holley 750, 230/230 @ 50 and .455/.455 lift. cam and nothing else fancy. The engine made 427hp @5100 and 525 ft lbs @3700 rpm. This cam might not sound like you want it though. I have been doing alot of research also because I'm about to have a 406 built with AFR heads and the xe284.
