xtreme energy vs voodoo - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2007, 07:17 PM
does anyone know if there is a big difference in the two. i know there is diff profiles but is there a big difference besides the price.
Old 03-08-2007, 07:27 PM
techinspector1's Avatar
Wiki Edits: 326
Compcams and Lunati are both well respected cam grinders. Consult with the tech guys at either company for a recommendation of the best cam for your application.
Old 03-08-2007, 08:02 PM
Bumpstick's Avatar
Hammer and a torch
The Voodoo series is supposed to be alot more valve train friendly and still have loads of HP like the Bracket masters series... They are a little newer designs than the Comp Extreme series but they too are for sure a good design...
Old 03-08-2007, 10:20 PM
Ozz1967's Avatar
Air Force Guy
The voodoo series are, as far as I know, a flat tappet design only...They don't offer roller options. The Extreme Energy can be had in both flat tappet and roller design.
Old 03-08-2007, 10:38 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I dont know if it means much but the voodoo cams are on a 112lsa and the xtreme energy have 110lsa
Old 03-08-2007, 11:45 PM
coldknock's Avatar
They're both fine lobe designs. Make sure that you use the recommended springs with either of them.
Larry
Old 03-09-2007, 04:29 AM
Guy Hiltz's Avatar
The Voodoo line is available in a roller type.Both of these cam series were designed by the same man,the Voodoo was probably just a bit better thought out.If you go roller,the Voodoo comes on a billet core whereas the Comp XE comes on an austempered ductile cast iron core,unless special ordered.
Old 03-09-2007, 09:26 AM
Big Mouse's Avatar
Stroked Z28
Does anybody have any comments on valve train noise with XE cams? On another forum, several people commented that their XE cams made a lot of noise in their SBC's... something about the grind was very steep...
Old 03-10-2007, 09:27 PM
327NUT's Avatar
F-Bird.....question, why is it that the XE cam is more noisey? Is it the faster ramp angles or what. I,ve got an XE262H-10 iin my 331" sbc but its unfired so can't compare.
Old 03-10-2007, 09:55 PM
327NUT's Avatar
So then its basically the valve rapidly closing against the seat that makes the noise? You think theres a longivity problem with this cam? I,m running Edelbrock alum. heads, they claim 120# on the seat and 320# open @ 1.219'" And I run 15w40 Rotella in my Powerstroke, I was looking at all the different oils but I keep coming back to Rotella for this engine.
Comp Cams xtreme energy cam - big Block JamesRS Engine 7 11-18-2011 08:22 PM
xtreme energy 268h malibumuscle81 Engine 37 02-11-2007 09:02 PM
Steorn, Ltd. offers free unlimited energy for suckers Jon Hotrodders' Lounge 2 08-19-2006 06:11 PM
Ethanol yea or nay hotrodgrasshopper Hotrodders' Lounge 30 03-30-2006 01:54 AM
Extreme Energy vs VooDoo cams Warrant Engine 10 03-08-2006 04:02 PM
