http://www.compcams.com/Cam_Specs/Ca...?csid=404&sb=0 |
This cam will work just fine.
95% of the "marine cams" used by Mercury Marine, OHC etc are direct copies of the factory GM performance cams used in street motors. Some odd ball Big block marine motors had special cam grinds. Some had reverse crank/prop rotation requiring a reverse grind cam. Some used the Good "Taxi" hyd lifters and premimum quality cam cores. With Marine water cooled "WET manifolds" you want to avoid excessive cam valve overlap valve timing to avoid getting water sucked into the marine engine at idle. You also want a smooth low rpm engine idle speed to allow easy outdrive shifting and docking. So they typically have a wide(er) cam LSA to reduce valve overlap as a rule. Other than that, no difference. |
| roller cam selection for my monte ss | redbandit98 | Engine | 37 | 06-21-2008 10:39 AM |
| Cam button length/clearance..? | mrdreex | Engine | 1 | 04-12-2008 10:17 PM |
| Cam Selection and Dynamic CR | Arcuden | Engine | 10 | 03-23-2008 11:03 AM |
| I need cam help | 355s10 | Engine | 7 | 03-16-2008 05:34 PM |
| Help Me Pick A Cam | Canadian Charlie | Engine | 2 | 11-16-2005 01:11 PM |
