y block remote oil filter - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 01:47 PM
I am currently installing a 292 y block out of a 62 ford F100 into a 52 ford p/u.
The current cartridge/canister type oil filter hits the steering box. I'm looking for a remote oil filter that would fit the 4 1/2" dia. mouth opening at the block. Everything on the market I have been able to find has a 3 1/2 dia. opening and will not cover the filter feed hole coming from the block.
Any ideas ???
Old 04-05-2011, 02:01 PM
JeffB's Avatar
Google this company: Exeter Auto, they are an Offenhauser dealer they did have these available as did Trans-Dapt at one time,Trans-Dapt has discontinued a lot of the older parts.
Old 04-30-2011, 10:09 PM
Y block oil filter
Will any of these Y block photo's help you out. I had four and all were setup with a remote oil filter. I used a canister type and located them on a bracket on the inner fender on the right side opposite the steering mechanism.
Normbc9
ID:	54887   Click image for larger version
Name:	312 McCullochYblock.jpg
ID:	54888   Click image for larger version
ID:	54889   Click image for larger version
Hydraulic Clutch reservoir - remote or not remote if possible? ClassicDriver Transmission - Rearend 6 03-09-2010 05:40 AM
Converting late model 98 block to standard oil filter fitting TNshadetree Engine 5 07-03-2009 08:00 AM
Remote oil filter; how far from engine block? Steam Roller Engine 2 04-20-2004 11:01 AM
remote battery, remote disconnect for fuel pump questions. Jared Engine 1 03-16-2004 10:33 PM
v6 remote oil filter? sosky Engine 3 03-31-2002 03:05 AM
