yahoooo..I cut my windshield and installed it. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2011, 07:48 PM
DARK SIDE's Avatar
Yessssssss. cut my windshield 1/4 in and installed it all in 1 afternoon..Fits great and looks even better.. Used my old glass grinder from when I did stained glass windows. Its a diamond bit sitting in a water bath..Boy am I happy..
Old 10-09-2011, 10:34 PM
redlightning's Avatar
Awesome! Could you post a picture of the glass cutter that you used?
Old 10-10-2011, 08:13 AM
cboy's Avatar
Last journal entry: Finished
Don't know what Darkside is using...but here is the glass grinder I have used for trimming auto glass. I don't think I'd want to try cutting away 1/4" of glass with this unit, but it works for shaving away small areas to get a nice, tight final fit.
The "screen" section on the top of the unit has a water reservoir under it. The water is wicked up to the diamond grinding wheel by a small piece of sponge...which you can see if you inspect the photo closely.
Always learning...and sharing what I've learned.
Old 10-10-2011, 08:58 AM
Very interesting looking tool there Dewey.
Old 10-10-2011, 10:56 AM
cboy's Avatar
This is a grinder designed for stained glass and NOT for tempered automotive glass or laminated windshield glass. However, like Dark Side, I have used it on occasion for shaping laminated glass. I have also used it to round the edges of tempered glass. But I don't recommend running out to buy this tool if you are looking to do a top chop or cutting down some glass for other reasons.
I've been told it is particularly risky to use this type of grinder on tempered glass due to the internal stresses that are built into that type of glass (commonly used in your side windows and rear window.) The entire piece could potentially shatter in your hands if the wheel catches an edge wrong. I think most professional glass cutters with automotive experience would be mortified to see this machine used for cutting down or shaping tempered glass and probably laminated glass as well.
I have used it in a pinch but I'm not going to go on record recommending it to others. You do so totally at your own risk.
Old 10-10-2011, 08:05 PM
DARK SIDE's Avatar
cut glass
The picture is just like the one I used. I tried it on my broken windshield first. I jammed the the windshield in and went back and forth and pushed hard then soft. Wanted to see how hard I could go before I broke the glass. Didn't break the glass and did a great job . I cut a grove 1/2 deep in about 2 minutes. It might not be made for this but I had no where to turn because nobody would do it . As I say it worked for me.....yesssssssssssss.
Old 10-11-2011, 07:33 AM
Old Fool's Avatar
m20 to be installed! pixelmonkey Transmission - Rearend 8 12-07-2010 02:33 AM
Bbc 402 Installed In A 1980 Z28 Camaro What Should Be Installed For Coil Spring Glen Rogowski Suspension - Brakes - Steering 3 06-21-2009 10:57 PM
How not to have a windshield installed 50 chevy p/u Hotrodders' Lounge 0 04-06-2007 07:14 AM
Any Model A with a T-5 installed bluestang67 Transmission - Rearend 4 03-09-2007 11:05 AM
4:10's installed Rubberman2003 Hotrodders' Lounge 8 09-12-2004 03:58 PM
