yank out a 727 ~ how difficult ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2006, 04:50 PM
amateur gynecologist
Hey ya'll ~ I bought a 1968 Dodge four door pickup from an old hippie type awhile back for the princely sum of $300 and though it's original 383 still starts and runs like a dream it's 727 tranny is as dead as Julius Caesar.
I was an army mechanic for the better part of a decade but have never yanked out a tranny on my own though I've helped lots of buds yank and stab 'em.
Crawlin' under this thing it sure looks pretty straight-forward.
How heavy is it ?
Any tips to give the feller (not me) who's going to rebuild it ?
Anyone know of a shift kit they'd recommend for it ?
Also, any of you MOPAR guys have any thoughts on the weaknesses or strengths of the 383 ?
Any thoughts/comments are greatly appreciated and thank you !!!
Old 08-27-2006, 08:58 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Well there are 2 ways to pull it out . . .
If you are NOT going to put it back into the truck . . .
FIRE up the torch & cut the drive shaft , cross member ,shift linkage ,speedo cable ,transmission lines & {maybe a down shift cable or linkage . . . . WATCH OUT FOR GREASE FIRES!
Then with a long 1/2" extension blow the bell housing bolts out & let gravity take over.
If you plan on putting it back together
Well thats different too. . . . .
You will want to UNBOLT all the stuff listed above & undo the torque converter & lower it to the ground with a transmission jack or a floor jack.
Unless you can bench press 200lbs & hold it use hydraulics!
You can pick up a mechanical trans jack or a adapter for a floor jack @ Harbor Freight for CHEEP
good luck
"SlowRide66"
"Illegitimis non carborundum"
YANK 3800 stall Test Video black66 Transmission - Rearend 5 05-16-2006 09:50 PM
727 Upgrade? polkat Transmission - Rearend 1 04-03-2006 09:43 PM
727 output shaft spline fat50 Transmission - Rearend 4 10-05-2004 06:49 AM
87 ramcharger 727 tranny questions 74huggerorange Transmission - Rearend 0 04-14-2004 08:52 AM
727 behind 331 hemi? KLRS10 Transmission - Rearend 3 02-20-2004 05:27 AM
