Ye' Olde "31 Ford progress - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2008, 06:50 PM
NOTE:: I just copied and pasted this so its really chopped up. sorry, too lazy to fix it, deal with it. Haha
Got power about 2 weeks ago so ive been at the barn every night after work. Havent done much but i have done alittle. Stripped my wheels and gave them a nice coat of paint. Threw in the 327 and trans, just need to get a mount for the trans and pull the body to get it all in. And tomorrow i think ill get to patching the floor and cowl.
And this past week i splurged and bought a whole bunch of parts. Just waiting on my steel 32 shell and some special parts.
Heres some pics of what the car looks like now, not much different than when i posted last.
Well.. got some more work done this past week. Monday i put in new cowl patches, and got a lovely sunburn. They turned out pretty crappy but theyll work. Forgot i had the long reach clamps at the barn... duh. Made some floor patches yesterday since it was raining and couldnt weld outside. I think they came out pretty nice. And today got a late start so i cut out the old front section and tacked in the new section. Got my tires mounted today too. So im moving along and should have the rear in this weekend if things go as planned.
Old 06-03-2008, 09:18 AM
cyclone-rods's Avatar
Bodies, Frames & Radiators
looking good so far....... be sure to send us an update as it comes together!
Old 06-07-2008, 08:44 PM
Got some more done this past week. Kept forgetting my camera so ive got these crappy cell phone pics. Last weekend i stripped and cleaned the engine. Got rid of the chevy orange along with the 20 other layers of paint. Painted it a nice gloss black. Threw on the new water pump and pulleys. Painted the ram horns white and slapped those on to see what it would look like (sorry, no pics of that) And i got some early chrome chevy stamped valve covers that look o so good against the black. Been getting more parts this week from The Hot Rod Company and Riley Auto, thanks guys, was great dealing with you. Took the body off on thursday night. Yesterday i put the front end together with my new drop axle. Put my f100 spindles on. Then today, stripped the front fenders getting them ready for some repairs. Then it got too hot around 3ish so i went inside and stripped more paint off some of the smaller parts and painted those. Heres the crappy pictures of the progress but ill get some better ones tomorrow.
Old 06-27-2008, 08:31 PM
Well ive been working a little every nite on the murray and ive gotten a bit done since i last posted. Been stripping the panels pretty much every nite this week and painting a few odds and ends when i had nothing else to do. Also painted the trans and cleaned it up good. Tried to attempt to install the lockup kit but that was a no go. And i put my axle together for the final time, this time with backing plates and i clearenced for the brake cylinders since im using the earlier round spindles. Otherwise thats been all ive been up to. Heres some pictures of most of everything that ive gotten done.
Old 10-02-2008, 07:53 PM
Well ive gotten alot done.. but i just copied my latest post from other forums that i visit more frequently. Alot more has been done than what i described.
Well didnt get much else done but it looks more like a car. Found flexplate bolts while i was cleaning up so i got the motor and trans together. Put that in and redrilled holes for the trans mount. Mounted my shifter to get the linkages made and make sure it works before i set the body on and mounted the ebrake handle. Ran the rear cables too, just waiting on the ebrake arms that go inside the drums and i can hook it all up. Thats about it.. hopefully ill get some more done after i get back from the jalopydrags.. haha
Old 10-03-2008, 07:23 AM
Irelands child's Avatar
I always like seeing a '31 Slant being built. It's starting to look good though your split radius rod system does concern me.
I started a Slant then got the bright idea that a roadster would be better, then some guy made me an offer that I couldn't refuse so........with more $$ in my pocket, off I went. Now I wonder about my decision.
How come the '30 running board splash shields - or were they on it when you got it?
Old 10-03-2008, 03:43 PM
It came with the '30 fenders but i got a set of better '31 fenders that im still working on.
Old 10-03-2008, 03:55 PM
AH Ha.
I have been trying to figure out what this is for almost four months...I knew it was a '30 something delivery...Ha Ha. If I see what I think I see, this is the same car as your 31 Ford. What do you think?
Bear with me in case the image didn't make it. New to the site and not up to speed on features.
Name:	31 ford small.jpg
Old 10-04-2008, 07:15 AM
That's not a Ford - the firewall and double raised detail down the side are 'wrong'. There also is too much wood showing where the '31 Slant Windshield Model A had none over the doors but a small amount for the top. A '31 Slant is real close to a '32 Fordor and I believe it was Ford's idea to 'test' many improvements before incorporating them into the '32 sedan. And what's even worse, I have no idea what your's is
I think if it's mostly complete, that it would be an interesting car to build - and either on an 'A' chassis and use their boards and fenders or a deuce. Someone here will identify it for you.
Dave W
Old 11-09-2008, 11:40 AM
Well ive been busting my *** in the cold the past few weeks trying to get everything finished up on the body before it got too cold. I replaced the rear wheel wells and structure underneath, welded in the floor panels, molded in the panel, and did all the bondo work on the body and fenders. Primed the fenders last night and i por15'd the whole inside the other week. Kept leaving my camera at home so here 2 crappy pics i took. Ill have some better ones once i get it painted... hopefully this week
Old 11-16-2008, 06:01 PM
Heres a little more. While it was nice yesterday i moved some stuff around and made some room to make a paintbooth but havent built it yet. So i moved the body and got it over on its side so i could por15 the bottom and undercoat it. It was warm yesterday so the paint dried quick but i think itll be a little longer for the undercoating, dropped into the upper 40's today. And i spent the past couple days getting the primer smooth on the fenders and body. Looking pretty and cant wait to get it painted, maybe next weekend since its supposed to be warmer again. I know its not much progress but atleast its something.
Old 11-30-2008, 07:33 PM
I guess im past my paint window so its not getting painted until spring. Hasnt been warmer than about 40 the past few weeks so im done. So friday night i decided to put the car together. Had some stainless bolts so i put the rear fenders on and stuff, threw the body on the frame. Thought the weight of the body would bring the back of the frame down but i was wrong. Its got a wicked rake that looks good but i think im going to make the new main leaf for the rear to bring the back down. So now i just need to order a crap load of bolts nuts and washers to put the rest of it together. Ran fuel lines but i still need clamps towards the front. But i think its looking good eventhough i still have a lot left before i can drive it.
Couldnt roll it out since it was raining/snowing/slushing out so the pics are really crappy.
Look at that fine ***
46 ford p/u model # ( WRONG ) ? biglee550 Suspension - Brakes - Steering 19 03-17-2008 08:45 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
Progress Report: Ford Six Hop Up Hot Roddin' Rocko Hotrodders' Lounge 3 11-02-2002 02:56 PM
Ford Race Engine BarbWire Engine 7 10-18-2002 11:38 AM
