year of casting numbers on engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2010, 07:08 PM
need engine id on casting number cfd 5748654 maybe 1957 oldsmobile rocket 88 also camero casting numbers 3970010 d216
Old 10-12-2010, 07:56 PM
ericnova72's Avatar
More for Less Racer
3970010 is a common '68-79 350 block, can be either 2 or 4 bolt main.
Old 10-14-2010, 09:08 AM
casting numbers search for 50 s oldsmobile
need year for 50 s oldsmobile rocket 5748654 numbers on the block
Old 10-14-2010, 09:21 AM
need year of casting numbers cfd 574865 should be 50 s oldsmobile rocket with a four barrel intake four speed hydro trans.
Old 10-14-2010, 10:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Try looking for the stamped in numbers. From http://www.442.com/oldsfaq/ofblk.htm:
The VIN derivative stamping or engine unit number on the left most side of the block, on the driver's side, just below the cylinder head, toward the front. The pad is part of the engine and will indicate the year of manufacture, but that is usually rusted beyond recognition, and it can be changed by restamping. If the engine was replaced under warranty, the pad may be blank. Rubbing alcohol and Q-tips help to remove the grime and grit from the stamping.
Engine casting numbers and vin numbers drfo Engine 5 06-18-2010 05:15 PM
Buick 430 Engine 70LEBUICK Engine 5 02-24-2010 09:57 PM
Help with SBC casting numbers wickedtone83 Engine 4 02-02-2010 02:56 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
casting numbers ??? jackyandjoe Engine 5 07-01-2003 05:11 AM
